10-29-2003, 03:26 PM
Mini-Z Turbo
Have any of you other Mini-Zers tried installing an aftermarket turbo that we use on Mini-Z's into your Xmod?
10-29-2003, 04:51 PM
dident know mini z's had turbo??..how is that possible
10-29-2003, 05:58 PM
There are many aftermarket turbos for Mini-Z's. Basically, you attach them to the batteries and the motor and they somehow bypass the stock ESC.
10-29-2003, 06:54 PM
Bad Driver
It will likely work just fine. The XMODS work on the same principles as Mini-zs.
Oh, a "turbo" is actually an external motor controller, it has nothing to do with forced induction.
10-29-2003, 09:23 PM
dont you lose reverse/brake with most turbos?
10-29-2003, 10:32 PM
Bad Driver
Only some, the $30 "twin turbo" can be found at tower, and it has forward, reverse, and brake.
10-29-2003, 10:41 PM
u think that would be possible 2 fit in the XMOD????
10-30-2003, 04:31 PM
What kind of gains would a turbo give? more torque, top speed? Is it worth the $30?
when you've tried everything and you still lose, there is only one answer, NOS
10-30-2003, 06:53 PM
Bad Driver
Yes, it would fit.
The turbo is worth it if you want to run a highly modified motor like those sold at minizracer.com. It will give more tourqe with normal motors due to less resistance and higher current limits. The speed may increase due to the low resistance as well.
11-01-2003, 04:12 PM
Yes, it would fit.
ill be installing a p03 motor and turbo sometime next week
11-01-2003, 05:33 PM
whats the po3 motor out of?
11-01-2003, 10:57 PM
its a racing motor for the mini z's it has a ball bearing can and neo magnets... IE it goes REALLY fast
11-02-2003, 10:47 PM
caan u get this at the hobby shop?
11-07-2003, 01:31 AM
VIPER let us know how that motor works out
