Old 10-27-2003, 08:45 AM
mbartell mbartell is offline
so I re-wired it
Quick gear changes
I got tired of taking it all apart to change out the gears. So I modified the rear top plate.
All you gotta do is cut out a slot in the top plate large enough to allow the gears to slide in and out of the space between it and the motor mount.
Take the rear suspension off as a unit- 4 screws (2 on top near battery holders, 2 on the bottom) put a gear in the space between the motor mount and the top plate, and mark the area that will allow you to just drop the gear in.
Take the plate off, cut out the marked area, and bevel the edges on the bottom.
Re-assemble it, and you are done.
Now, when you need to change your gears, you just pull the 4 screws out, slide the suspension off, shake it upside down and the gear falls out- drop your new one in and that's it. You may need to manipulate it a little to get the shaft back in, but it's a lot faster than dissasembling the whole thing every time.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
Old 10-27-2003, 03:27 PM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
Good idea, thats probally why I designed it into my chassis I finally cut on saturday.
I just have a small 2mm cut so that little pin on the gear doesnt catch, it comes out without a fuss.
Old 10-27-2003, 08:21 PM
STFU Tuning STFU Tuning is offline
Send a message via AIM to STFU Tuning
do you have a picture of this mod?
Wheel Weights! Steve ZipZaps Monster Truck 54 05-24-2006 12:40 AM
"the need for speed: a fast MT gearbox" chilli_mp138 ZipZaps Monster Truck 1 12-20-2005 05:58 PM
The maximum gear ratio..... charliebrown ZipZaps 9 01-13-2004 03:55 PM
Equation for scale speed and gear ratios. Zephyranthes Bit Char-G / MicroSizers 0 02-10-2003 06:34 PM
Quick gear question.... MicRoMaN Bit Char-G / MicroSizers 0 12-24-2002 08:11 PM
