10-25-2003, 11:30 PM
Skid Plate
While I was waiting for the paint to dry on my Gunmetal Skyline, I decided to do the upgrades on the chassis. One of the extras I did was to make a skid plate for the bottom.
I used some #255 aluminum (.016" thick) I found at the hobby store. I made all of my measurements and cut it with some regular scissors. I then used a file to round and smooth the edges. I used a hand drill to cut out a slot for the switch and drill the 2 holes for the screws to hold it. I used the 2 screws on either side of the switch to attach the skid plate.
I left the plate short of the rear so I had access to the body tab/hook and lock. I can still remove the batteries by only removing the upper clips and just pull them out.
Here is an under shot...
10-25-2003, 11:31 PM
As you can see, the plate doesn't effect the ground clearance.
10-25-2003, 11:32 PM
I bent the front upward and in front of where each battery compartment sticks out.
Zhuge Liang - My Idol
good job. hey um how much did the aluminum cost? and it'll just come off if u just unscrew it right? i dont have access to any powertools with me so if i sent u money can u send me a piece that's ready to be fitted on? my email is danktrees1212@yahoo.com if u would be willing to discuss this.
10-25-2003, 11:40 PM
Got Mini-z?
i think these somthin wrong with this site...i just posted somthing and you had 3 pics up...then i went to refresh and you only had 2....then i hit refresh again and i saw heat posted..then i hit refresh again (still looking for my post) and saw another picture that got posted before heat posted....so then i went back into the history and found where i posted..i hit refresh there and it said this thread has probaly been moved or somthin(  )...o well..lucky i copied it...this is wat i wrote..lol
^^^you do not have to read this if you dont want to^^^^^
great mod again BC! i really need to get to my hobby shop and start doing these mods ....i can't wait to see you gn metal skyline
10-25-2003, 11:43 PM
The aluminum was a whopping $1.20 for a 4"x10" sheet. I really don't want to get involved in making things for money and sending them off in the mail, but I could draw a layout with the measurements and post it here. The only tools you need are a pencil, something to measure with, scissors, and a hand drill (looks like an x-acto knife, but with a bit), or you could use a pair of pliers to hold a drill bit, and a file.
10-25-2003, 11:45 PM
if u could do that i would appreciate it
There was nothing wrong. I accidently posted too big of a pic the first post, and for some reason it wouldn't let me edit it, so I had to delete the thread and re-post everything.
Sorry about that.
10-25-2003, 11:50 PM
whoa, great mod.
I am the insider, i kno all
current xmod stats: everything. i got the hook up =P
10-26-2003, 12:09 AM
Thanks!
Sorry about the crappy drawing, but it is 1:00 a.m. here so....
This is for a chassis with the batteries in the rear position. If you have something different, just move those pieces towards the front however much you move the batteries. You could also just go ahead and move it up some and be covered for all settings. The dotted lines are where you bend upward.
10-26-2003, 12:13 AM
what size chassis is it for? (ex: rsx length, skyline length...)
10-26-2003, 12:17 AM
Got Mini-z?
nice drawing...couldn't that sorta also be used as a chassi diagram to make a custom chassi...im not sure..it like 1:30 over here too...im not thinking straight...
10-26-2003, 12:18 AM
Mine is a Skyline, but the pecies in front of the tires are far enough foreward it would hit on a short chassis. The only thing you may have to do is shorten the rear up to clear the differential hump in the chassis and access to the tab lock.
Disclaimer:
It's always better to measure yourself. You can use this drawing as a guideline.
10-26-2003, 12:48 AM
is the goal to this mod to just prevent and underbody scrapping? or to also protect the car from snapping any pieces?
10-26-2003, 10:24 AM
i would say its mainly to prevent underbody scraping.
