Old 10-23-2003, 02:12 AM
lilcricket lilcricket is offline
Send a message via AIM to lilcricket
all this talk about mosfets and 'fets'...
so what are they really? and, by upgrading them, what can i achieve?
Old 10-23-2003, 02:23 AM
I have a beach ball...
Do a search in one of the bit forums or the zipzap forums. Basically they replace the transistors on the PCB with MOSFETs that have lower internal resistance. Less resistance means more current gets to the motor and it goes faster.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 10-23-2003, 03:03 AM
how involved is this, meaning can i do it myself, with a soldering gun, or what?
Old 10-23-2003, 09:48 AM
mbartell mbartell is offline
so I re-wired it
Actually if you look up mini z fets you will find a lot more about them, and what they do. Basically it's a switch that can limit the amount of current going thru it. As you get a better one, or more of them, it's easier to pass the current thru in a controlled way.
It really comes into play when you have a motor that demands a lot of power, and it "pulls" current thru the fet and heats it up. There are motors you can get that will fit these things that will pull 2 amps!
That's why you would want to upgrade- it'll keep the circuts from litterally burning up.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
Old 10-23-2003, 06:17 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Unfortunately, It looks as though there is not enough room on the PCB for more. I'm gonna try and make an external turbo from Radio Shack MOSFETS . Should work pretty well.
Old 10-23-2003, 09:24 PM
Silent_NightR34's Avatar
Got Mini-z?
or you can do an external...
Old 10-24-2003, 10:45 AM
so I re-wired it
mini z turbo?
Have you guys looked at the mini z turbos? There are about 4 or 5 companys that make them, and they may work- Most cost from $12 to $25 and they are supposed to plug in on the mini z's- not bad for something that already exists, and may just plug in.
how much different can it be?
anyone messed with one?
Famous last words:
Old 10-24-2003, 07:49 PM
rucrazy4rc rucrazy4rc is offline
external turbo
tried it ,it is not working need possible solutions ??????here is the color code red and black wire ,battery case,white and blue wire pcb board ,white positive, green and yellow wire motor....
steering works after wiring,turns left and right off the controler but throttle not working ,checked all the wires,......solutions ?????
reverse fets f150monster ZipZaps Monster Truck 0 03-27-2006 11:05 PM
mosfets chinkst3r XMODS Mods and Projects 1 07-20-2004 10:02 AM
Using non logic level fets bob256 XMODS Mods and Projects 3 02-06-2004 07:01 PM
stacking Mosfets aperson XMODS 0 12-16-2003 12:54 PM
