Old 10-23-2003, 12:58 AM
seth98es's Avatar
seth98es seth98es is offline
Driveshaft...
is the driveshaft really needed if you are running RWD? Obviously for AWD its needed, but for RWD you are just spinning it for nothing. Any thoughts?
Old 10-23-2003, 01:35 AM
lowridetractor lowridetractor is offline
Send a message via AIM to lowridetractor
yes you do need it because it keeps the gear between the motor and the diff from jumping around and striping out eventually
Old 10-23-2003, 01:41 AM
seth98es's Avatar
Thanks, I took it out and put it back together and the gear didnt seem too stable so I put it back in
Old 10-23-2003, 10:37 AM
rogotiz3
I took mine out, but the thing is, my pinion gear is the yellow one and i'm using the stage 2 blue motor, but I also had to trim the motor mount to do that. perfect gear mesh without the shaft.
non-evo driveshaft problem (slides forward in a crash) bholio XMODS 0 11-26-2005 10:53 AM
CF driveshaft duwain XMODS Parts and Hop-Ups 36 11-18-2004 06:06 PM
Alternatives to a CF driveshaft Billiam_Returns XMODS 2 07-13-2004 10:21 PM
I have a new driveshaft idea viperdout XMODS Parts and Hop-Ups 2 04-26-2004 11:50 AM
Plastic Driveshaft hpbw2k XMODS Mods and Projects 20 02-27-2004 08:07 AM
