Old 10-22-2003, 08:15 PM
NOS man's Avatar
NOS man NOS man is offline
SHYMERLOO!!!!
Send a message via AIM to NOS man
stuttering?
my x mod stutters. i put new batteries in the controller and the car? whats wrong?
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
Old 10-22-2003, 08:29 PM
catman25 catman25 is offline
i had the same problem all i could do was return it.i think it may be a motor problem seeing how mine did it in foward and reverse.
Old 10-22-2003, 08:36 PM
NOS man's Avatar
SHYMERLOO!!!!
did anyone else have this problem?
What IM rUnnin
All Wheel Drive
light set
nimh cell upgrade.
smoke exaust
Old 10-26-2003, 08:36 PM
broncomaxx42 broncomaxx42 is offline
stuttering
Got my Xmod two days ago(Skyline). Worked great until I ran into a table leg. After that, it would stutter and the steering would be erratic. I have some experience with 1/10 scale R/C and know that the receiver crystals are sensitive to shock. Also, if the two 'prongs' on the crystal don't fit snug into the receiver, that can cause erratic operation. I removed the receiver crystal and slightly bent the prongs(be careful not to break!)so that the fit was tight. Good as new! I no longer have any problems with stuttering, even on low batts. I also noticed the 9v. wasn't making good contact with the terminals. Fixed that with a piece of paper.
Hope this is of some help
Old 10-26-2003, 09:26 PM
wasuri's Avatar
wasuri wasuri is offline
Send a message via AIM to wasuri Send a message via Yahoo to wasuri
Yup, same problem with a lot of people....if you smack a wall and you studder just take the crystal out and put it back in. Good as new....
Old 10-27-2003, 05:35 PM
Spike88DS's Avatar
Spike88DS Spike88DS is offline
My MoMmY SaYs Im SpEcIaL
Send a message via AIM to Spike88DS
ya but what about zipzaps my studers all the time since i drove it off my comp desk and broke my mustubishi eclips spoiler
just say to your self when you get mad what would jesus would do....then say to your self wait y are you talking to your self
Old 10-27-2003, 05:40 PM
viperkilla's Avatar
Acura RSX
There could be some kind of interference. My zip zaps sometimes get interference when I am playing with them.
Old 10-27-2003, 09:18 PM
ZZ stuttering
As far as the Zip Zaps go, it could be the same problem(crystal).
However, the crystal in the ZZ is directly attatched to the P/C board. A friend of mine had the same problem with stuttering and we traced it to the crystal, but couldn't fix it. You might check the antenna at the point it attaches to the board. Sometimes the wire will come un-soldered. For that matter, check all of the wires where they attatch to the board(motor, battery, etc...).
One last thing to check is that the battery(in the car) is making good contact. That's about all I can think of..........
Old 10-28-2003, 12:00 AM
Firepony's Avatar
Firepony Firepony is offline
Send a message via ICQ to Firepony
I just made sure the crystal was all connected good and it cured the shutter thing
Old 11-08-2003, 01:01 AM
ninja828 ninja828 is offline
i have a range problem on my skyline too. i've checked the crystal and everything else but i can't figure out whats wrong
Old 11-09-2003, 02:21 AM
Hudson5150 Hudson5150 is offline
Send a message via Yahoo to Hudson5150
Ninja828 Some of the Skylines have had range problems from the factory. You should return it for a new one.
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
Old 11-30-2003, 09:55 PM
yz85rider yz85rider is offline
My sklyline will go 10 feet and die. what up with that!!!!???
Old 12-01-2003, 02:13 PM
duwain
i have a red supra and its good until about ten feet and then it starts studdering. i think im gona take it back. the crystal seems to be fine.
Old 12-01-2003, 03:57 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
did you guys check to see if the wire going to the antena is still connected?
Old 12-01-2003, 05:27 PM
mine was disconnected, but I soldered back on.
Stuttering? geofroley Bit Char-G Mods and Projects 1 11-21-2003 09:46 AM
Car was fine now stuttering how to fix catman25 XMODS 10 11-17-2003 01:34 PM
Stuttering? tobenjunk ZipZaps SE 17 09-27-2003 07:40 PM
Stuttering Shen? Buzzbait Bit Char-G / MicroSizers 10 04-28-2003 07:33 PM
4-Band Rev 5 Stuttering Usulsuspct Bit Char-G / MicroSizers 1 12-08-2002 11:22 PM
