Old 10-22-2003, 06:18 PM
shrubba shrubba is offline
Weak Steering servos? is just me?
I got my xmod on Monday.
I was sold on the AWD system.
Once I installed the AWD set up w/ ball bearings too... my steering is pathetic! it will not steer all the way either left or right, and there is nothing obstructing movement...
even if I hold the car up, wheels in the air, give it throttle, and try to steer, it just can't turn all the way not even half way, and yes I have checked the steering range setting on the controler.
Any one else have this problem?
I have removed both the upper and lower screws holding the knuckles on to reduce any binding... seems just as smooth, but still no good.
Any ideas?
Thanks!
Shrubba
Old 10-22-2003, 10:32 PM
Got 4.2 King? I do : )
maybe some thing didnt slide together properly, take it apart and put it back together and see if you notice any thing out of place
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 10-22-2003, 10:58 PM
_revhards13 _revhards13 is offline
I think thier cute!
Send a message via AIM to _revhards13
get some nicd batteries tehy will give your car a huge kick in the ass, they made my drifter go from not being able to break ground to not being able to make ground...
Also, when i had the old batteries it woulndt turn all the way to the right, now it snaps there instantly...
All xmod parts for sale cheap check it out
http://tinyrc.com/forums/showthread.php?s=&threadid=15531
Old 10-23-2003, 01:07 AM
Jimmi94se Jimmi94se is offline
Send a message via AIM to Jimmi94se
I guess my servo is fried or just doesn't work. I have problems with my alignment and Drakeon4450 assisted me with a step by step process last night on trying to fix it. Worked great until I acctually drove it. So I'm taking it back tomorrow and seeing what options I get...maybe I'll get a Supra instead of my Skyline....
Old 10-23-2003, 06:32 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
my skyline did that after i changed the tie rod to a 3 degree one. i took it off and it still wouldnt thrun so i forced it a little while turning the wheel the same way and is stopped
NEVER UNDERESTIMATE THE POWER
weak steering? Racer9 ZipZaps Monster Truck 4 03-31-2005 05:45 PM
WOW, another steering discovery! Upgraded steering motor! cyborgzero ZipZaps SE 2 02-22-2004 01:16 PM
steering is weak freakanoid Auldey (All) 4 01-18-2003 05:25 AM
