Go Back   TinyRC.com > 1/24 and Smaller > Mini-X > Mini-X Parts and Hop-Ups
Old 10-19-2003, 10:29 PM
helldriver's Avatar
helldriver helldriver is offline
Send a message via Yahoo to helldriver
Talking CRAWLER X' coming..!
This' the dual-motor crawler x made of some Mini Xs pieces and some OL parts.
Hope by the end of the month this one can crawling.
Yes it still looks bad, but this is a start for the next rigid chasis.
Any comments?
Old 10-20-2003, 01:25 PM
3series takumi's Avatar
3series takumi 3series takumi is offline
mini-eX-Driver
Send a message via ICQ to 3series takumi Send a message via AIM to 3series takumi Send a message via Yahoo to 3series takumi
that is sweet!!!!
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Old 10-22-2003, 12:10 PM
Tbird Man Tbird Man is offline
I have something like this in mind, except it is gonna have the motors mounted on the chassis and driveshafts going to solid axles. and I am going to use a three point upper arm. and two two point lowers. instead of a 4 point setup. are the upper mounts on that bloted solit with no ball joints? and where did you get the links?
Old 10-22-2003, 09:42 PM
helldriver's Avatar
1. Can't put the motor on chasis, since I dont have any skill to make the U-Joint for driveshaft.
2. Yes it was bolted with ball joints.
3. The links is made of used Overland's street version shocks. I rid off the spring and replace the rod with screw. So the length is adjustable. I will post the pic soon. Now I'm working on my brunt stock ESC.
Old 10-27-2003, 12:39 PM
niceguyteddy niceguyteddy is offline
I have a question, how do you guys mount those wheels and tires?
I bought a Tamiya 1/32nd Blackfoot to do a monster x mod but am not sure how to attach to those hubs.
Mini-x: Subaru
6 Cells
Bearings all round
vented bearing can
O/l tyres
Old 10-27-2003, 08:12 PM
helldriver's Avatar
Just glue them to the stock wheel and trim it a bit.
See my pic.
Old 10-27-2003, 08:31 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Looks great helldriver! You should post this over at Mini-ZRacer.com as well, I think the Overland Mod'ers would love to see it!
Old 10-27-2003, 08:44 PM
helldriver's Avatar
Hahahhaaa....I think my post will make them think twice to buy the new MadForce.
Old 10-27-2003, 09:10 PM
tinyrc's Avatar
Old 10-28-2003, 01:34 AM
Hooters Driver Hooters Driver is offline
I have seen U-joints in just about the correct size available for R/C boat driveshafts. If you decide to try something like that Tower Hobbies carries the U-joints as well as matching diameter shafts and bearings.
Old 10-28-2003, 01:46 AM
helldriver's Avatar
Very interesting! I try to search down there.
TY!
Old 10-29-2003, 12:21 PM
Cheers for pick of wheel mod, Nice one!
Can you drill the wheel hub (before gluing) to enable you to remove the wheel??
Other wise you would be stuck with a monster mini-x (maybe no bad thing ;-)
Mini-x: Subaru
6 Cells
Bearings all round
vented bearing can
O/l tyres
Old 10-29-2003, 03:52 PM
DanielS DanielS is offline
Send a message via ICQ to DanielS
Hi
funny you had the same Ideas than I had
Mine is about the same stage than yours!
Yet I allready think I solved the engine Issue.
I will use am mini-z motormount and drive as a middle diff
As U joints I will use graupner boat stuff - and a single Ujoint per axle - and the shaft will also be part of the axle linkage.
So my first go won't have dual motors.
would like to stay in touch with you - btw do you know killers work from the TTTT forum - on this site? - you should really study it.
Old 10-29-2003, 07:52 PM
helldriver's Avatar
Originally posted by DanielS
Hi
Glad to have some friend with the same visions..!
Hi
Good idea. But it's quite expensive. I saw a guy that use 3 diff on his 1/24. Rear, front and the main diff.
I'm very frustrated about this one. Never find any here. I really want my truck seen as real as poss. Can you tell me the LHS that sell those things and the type fo u-joint?
Sure, I will post many mails to you about the U-joint and so on.
Killer? He was my inspiration to make this crawler.
Do you have some pics about this project? Let us see!
Drop me mail at wing@cbn.net.id
C U soon! Thank you.
Bye.
Old 10-29-2003, 07:55 PM
helldriver's Avatar
Sure. I drilled entire center section of the wheel, so I can remove/put the it anytime.
A Crawler zzultimate ZipZaps Monster Truck 10 08-06-2007 05:57 PM
Transformers ZipZaps coming in May !! truckian TinyRC.com Announcements 4 04-10-2007 07:52 PM
Highly modded crawler Hildy ZipZaps Monster Truck 3 07-11-2006 06:04 PM
1/24 Rock Crawler bluemonster TTTT 4 01-07-2005 11:27 PM
Epoch spec 2 bodies coming soon!!!!! Epochracer34 Epoch RC1/43 8 02-04-2003 09:15 AM
