Old 10-18-2003, 07:57 AM
Bad Company's Avatar
Something I noticed about the AWD kit.
Maybe cuz it's early morning here, but while I was sitting here installing the AWD kit on my Skyine chassis, I noticed how the kit appears it can only be installed in the longer wheelbase cars/chassis. Here is the problem. Once you install the front cone gear and the rear and go to slide the the rear end back on, it will only slide up the the last screw hole for your chassis wheelbase adjustment (the farthest towards the rear). My guess is you would have to cut down the shaft to be able to get it to fit the other 2 holes.
Has anyone installed the AWD in the RSX which has the shorter wheelbase?
Maybe I'm missing something, I just woke up.
Old 10-18-2003, 08:08 AM
airline2's Avatar
airline2 airline2 is offline
I Love Xmods
did you get it installed
Current Xmods Setup
Skyline with stock body and stage one motor drift, awd, lights
Old 10-18-2003, 08:13 AM
Yes, I got installed on mine, but I was installing it on the Skyline anyway, so it fit cuz of the longer wheelbase.
Old 10-18-2003, 08:52 AM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
That is kind of odd, so if you wanted to shorten the wheelbase of a car (2wd) the shaft would still be to long.That piece between the the front uprights looks critical to keeping the rear gear properly meshed.
There must be two other shaft lengths to allow the wheelbase adjustment.Shafts could be made very easily also, just need to get the right size rod and notch it.
Old 10-18-2003, 08:58 AM
duey's Avatar
duey duey is offline
will race xmods for food
Re: Something I noticed about the AWD kit.
I didn't have much of a problem besides the abudance of screws when installing the AWD on my RSX. I guess i would've finished sooner if i paid attention to the instructions lol
Old 10-18-2003, 11:11 AM
Maybe the RSX and the Civic have shorter driveshafts. I'll have to look into this when I install the AWD on mine.
Old 10-18-2003, 12:31 PM
cj1267's Avatar
cj1267 cj1267 is offline
CJ's Hobbies.net
Send a message via ICQ to cj1267 Send a message via Yahoo to cj1267
Can you get a measurement and pics of the RSX front drive end under the cover like I have seen of the Skyline?
Old 10-18-2003, 12:36 PM
Sure thing CJ. Which pic of yours are you refering to? Got a quick link?
Old 10-18-2003, 05:51 PM
I have a beach ball...
The shafts have to be different lengths. That's how they do it on HPI's Micro RS4, except it's belts.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 10-18-2003, 06:20 PM
XMODADDICT
say, mine fit...
hi, i'm new here but i got the rsx and my awd kit fit perfect but ididnt use the red arms or rear diff... i just switched sum of the parts b/c i was too lazy to change all the bearings again...try installing it again and if it doesnt fit again, the third time should be the "charm."
Old 10-18-2003, 06:33 PM
airline2's Avatar
I Love Xmods
Xmodaddict you helped me solved my problem with the front of my awd kit so now i don't need to returned and get another one thank's alot for the idea.
Current Xmods Setup
Old 10-18-2003, 07:18 PM
Geckoboy Geckoboy is offline
i have the RSX with AWD and it works great
the drive has to be shorter
Old 10-18-2003, 08:25 PM
gunner.inc gunner.inc is offline
heres a tip i have found that the stock ball diff works better than the one that comes with the awd kit just some info for every one hope it helps also has anyone found a way to add more aaa or convert to 9v?
Old 10-18-2003, 09:59 PM
duey's Avatar
please explain how/why it works better? i still have my supra and skyline that i haven't installed the awd yet (too lazy). If it does really run better i'll re-install my stock on in my RSX.
Old 10-19-2003, 12:24 AM
it seams to have better take off and more speed i dont know why has anyone tried a slot car motor other than me?
AWD Kit + Light set blind XMODS Parts and Hop-Ups 25 05-16-2004 09:58 PM
Which lower deck screws do you use for AWD kit? newbitowner XMODS Parts and Hop-Ups 5 01-31-2004 01:05 PM
The AWD kit is so hard to find now! newbitowner XMODS Parts and Hop-Ups 5 01-27-2004 06:30 PM
AWD kit question Murcielago659 XMODS 1 10-26-2003 01:44 AM
