Go Back   TinyRC.com > 1/24 and Smaller > Mini-X > Mini-X Parts and Hop-Ups
Old 10-15-2003, 06:40 PM
3series takumi's Avatar
3series takumi 3series takumi is offline
mini-eX-Driver
Send a message via ICQ to 3series takumi Send a message via AIM to 3series takumi Send a message via Yahoo to 3series takumi
new rims!!!
whoohoo!!! more rims to use. i took some of the new xmods wheels and put them on the minix with about 15mins of mod work. they look sweet! now i have 4 styles of rims to run with and better tires to use on them too!!
i love xmods or shall i call them mini-x-mods
next is suspesion!
i got a suspension set, a 3 rim style set, and 4 tire set kit for $28 at the local radioshack
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Old 10-15-2003, 10:36 PM
dgilpin dgilpin is offline
Are they wider than stock? If so, they might look better with the mini-x lexan bodies than stock rims. Do you think overland or mini-z or mini-x tires fit those rims?
Old 10-15-2003, 11:15 PM
mini-eX-Driver
they are about 1mm wider, they have a seam that runs along the middle that matches with the seam of the tires so they hold on. that will work for overland tires but not for miniz tires
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 10-17-2003, 12:32 AM
cdog4w's Avatar
cdog4w cdog4w is offline
newbmaster
Heh, ive been waiting to see if any xmods stuff could be used on the mini-x. So how much work did you have to do to get those rims on takumi?
I still have to wait for tiny to restock the mini-x wheel nut wrench, stupidly I didn't order it when I got my X. I suppose I could try something else, but I'll wait for the proper tool after half stripping many body screws already.
My rides:
Old 10-17-2003, 08:16 PM
mini-eX-Driver
it is very easy. the holes are the same size but xmod wheels hole had a flat side that grips to the xmod shafts. i just used a drill to get rid of that flat side and then used a dremel to cut a groove to fit the pin of the minix axles. about 5mins per wheel for me. i think that these rims work better than the original wheels cause they fit the axle perfectly.
as soon as a get a camera workin you will see my minix using the the spring suspension of the xmod. it looks just like a 1/10th scale turing car now. next i will put that suspension on the back and make sway bars. then i will be done with the suspension tuning
keep an eye out for my next post!
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 10-17-2003, 09:17 PM
cdog4w's Avatar
newbmaster
Awesome :P
Doh, I'm waiting for tiny to restock that stupid wheel nut wrench, tho I'm not even sure if my ratshacks have xmods in stock yet. I don't know much about RC suspension, is the design of the xmods suspension better than that of the Mini-X? My own take on it is that the Mini-X suspension looks like that of a toy while the XMods looks more like that of a real car (and by extension a 1/10 car as you say).
Anyway, excited to see how your suspension mod turns out takumi. Will you be able to adjust ride height with it? I know on the current X you can lower the rear, but not much else...
My rides:
lego tires, xmod rims Marius666 XMODS Mods and Projects 19 04-13-2006 08:53 AM
custom wide rims broke ess supra XMODS Mods and Projects 1 07-18-2005 07:59 PM
New DUB City Rims DriveWRX Bit Char-G Parts and Hop-Ups 20 12-08-2003 09:43 AM
Cool Alloy Rims cj1267 ZipZaps 0 05-09-2003 12:17 AM
