Old 10-03-2003, 09:52 PM
fireball16789 fireball16789 is offline
mutant car
i was making my car a dual cell today. i did eveything right. i soldered the wires on the extra battery. I didnt want to make it pemanent so instead of soldering the wire to the battery that was in the car i just used duct tape to get it to stay and just put the othere wire between the duct taped side and the terminal. i then charged it on my modified controler. when i took it off it wouldnt run so i put on the charger and ran i while it was on the charger when suddenly the wire became unsoldered but the car kept going(it was on the charger. i took out and disconected both batteries and it still ran while it was on the charger yet when i put in the battery and took it of the charger it wouldnt run(after i charged it). My car is meesed up and will run only on the charger with or without a battery. i even made sure nothing was connecting the terminals. Can anyone help me?
Ferrari Modena- perfection 4.2
Old 10-03-2003, 10:40 PM
Never mind.....i forgot that it always runs on the charger im stupid. nbut i still cant figure out why it wont run....all the cables are conected
Old 10-16-2003, 08:08 PM
T_T_52
I feel your pain and heres what you should check: battery contacts in car, the solder around the ground and other make sure that there is no solder touching another wire and thats all I know.
My Car doesn't work! Eyemfaster XMODS 2 03-02-2005 09:59 PM
my drag car 4 trade zombiebaby For Sale/Trade 5 01-25-2003 01:35 PM
What gears and motor should I use to get the most power out of my car with a trailer. AudiTF Bit Char-G / MicroSizers 6 11-14-2002 04:38 PM
Cat5 vs Cat5E for car antenna material mechanist ZipZaps 6 10-13-2002 12:59 AM
