09-30-2003, 12:53 PM
battery.................................
i'm kinda new here , and i would like to know wheter different types of battery affect on the speed of BCGs or the runtime only?
If it does affect on the speed , what's the most common and most suitable type that is used to achieve high speed?
10-03-2003, 07:09 AM
runtime only
10-05-2003, 10:41 AM
It's Really Fast!
True. But if you wire up to batteries Positive terminal to +battery, then - battery to a + second battery, then the - of the last battery to the negative terminal (1st battery can't touch the negative terminal, you not only get more total wattage to the motor (more speed), but depending on what types of batteries (you must use 2 of the same power batteries), you get more runtime!
