Old 09-29-2003, 01:22 PM
schmock schmock is offline
Unhappy gear and axle
i've encountered a problem here and really need help.
my BCG doesnt run well, cause of the the gear and the axle doesnt rotate together, so the gear tends to rotate freely whileas the rear wheels doesnt turn. Anyone has a solution??
Old 09-29-2003, 10:14 PM
adroit adroit is offline
Your motor is more than likely not mounted properly. Take out the motor and put it back in, insuring that the clip goes all the way in and has no play. Hope this helps.
Old 09-30-2003, 11:05 AM
zeronineUK zeronineUK is offline
you might want to check that the gear thing is the right way round. the larger section goes against the chassis.
hope i helped
Old 10-17-2003, 05:11 AM
ownzorzor ownzorzor is offline
If the gear on the axle turns on its own, then you'll have to dab a little bit of super glue or some other liquid adhesive to the axle right where the gear is. I remember someone mentioning this somewhere in another thread. If you add too much then the car will slow down due to increased friction between the chassis and the axle.
Repairing a worn rear axle retaining slot rfnagel ZipZaps 5 01-22-2004 02:37 PM
HELP Brand New Bit Char-G 1.0 Very Slow & Axle, Idler Gear Loose Sid Bit Char-G / MicroSizers 3 02-14-2003 11:37 AM
Seperating gear and wheel from rear axle Minisizer Bit Char-G / MicroSizers 3 01-12-2003 04:21 PM
what if i had the pinion gear straight to the axle? blacksabbath070 Bit Char-G / MicroSizers 6 07-15-2002 01:04 AM
