09-15-2003, 02:25 PM
Actually, they suck^
Broken steering- I'm mad!
I've had my se for 2 days now, and the steering allready broke!! I have no idea what happened, but now nothing happens when i turn left. I can turn to the right normally but it re centers slowly. I opened up the "servo" and everything appeared to be normal. Do you guys have any ideas before I return it to ratshack?
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Toy East Mini Cooper
1 Precious Clone
09-15-2003, 02:33 PM
I Love Xmods
i don't have ideas
Current Xmods Setup
Skyline with stock body and stage one motor drift, awd, lights
09-15-2003, 02:48 PM
gee, thanks
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Precious Clone
09-15-2003, 05:14 PM
custom title
Ignore airline, he is the most worthless poster ever!
Maybe a gear is stripped somewhere in the steering setup?
Can you manually move everything easily?
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
Plantraco desktop rover for sale
email me at eman54@optonline.net if you want it
09-15-2003, 06:46 PM
phear meh..............
check the steering trim on your controller........coulda been turned accidentally
09-15-2003, 06:50 PM
I've had this happen once. Come to find out, a piece of grit or dirt had gotten into one of the teeth of the flat gear and wouldn't allow the steering motor gear to go past. Make sure your gears are clean.
09-15-2003, 06:57 PM
I Love Xmods
bad company thanks for the tip in this does ever happens to me
Current Xmods Setup
09-15-2003, 08:40 PM
thanks a lot guys... ill try this stuff tommorow. The wheels turn perfectly fine manualy, so maybe there is some garbage in there.
airline2- i cant thank you enough for all of your help with this- youve given me some great suggestions...
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Precious Clone
09-16-2003, 12:21 AM
09-16-2003, 02:56 AM
ROTFLOL!
09-16-2003, 06:41 PM
Zip Zap SE Basher
Also, check the gear mesh...
Just a thought, even though I probably am wrong.
Or mabe bad contacts on the steering motor?
09-16-2003, 06:49 PM
thanks so much everyone (especialy airline2  ) I was able to fix the steering- Beleive it or not, it was the gear mesh. When I played with it last, i heard a snap in the steering. So when i was trying to fix it I snapped it back the other way, and its fine now.
Does the steering in anyone else's SE "jitter" when it returns to center?
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Precious Clone
09-16-2003, 06:53 PM
Zip Zap SE Basher
Yeah! I was right!!!!
Do I win anything?
09-16-2003, 07:52 PM
yes... you've won a thank you!!
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Precious Clone
09-16-2003, 07:53 PM
Zip Zap SE Basher
