Old 09-02-2003, 08:43 AM
boho's Avatar
boho boho is offline
Camera springs
Question about enamled wire
If a wire is enamled, does it keep from conducting to random things it may touch.
I'm curious as to why the tiny wires in a bit don't short each other out when they touch, and I was also wondering if I can use this stuff for the fet modding I'm trying to do. I'm having some trouble with the wires I'm using now. It's just regular coated (plastic?) wire about .5mm~1mm. I think it's something like 5 string.
Any help would be appreciated.
Old 09-02-2003, 09:19 AM
ph2t's Avatar
ph2t ph2t is offline
Chief Propeller Head
boho, I swear by the stuff.... enamled wire is insulated and you use the heat of your soldering iron to melt it away and expose the wire.
For solid core wire it is very flexible and doesn't break at all.
Any techo photos of my mods usually show i've got enamled wire in there somewhere.
ph2t.
Old 09-02-2003, 09:29 AM
boho's Avatar
Camera springs
Thanx P. Your picture and my troubles were what raised the question. I thought I could get away with regular wire because that seems to be what micro amps is doing. But I can't find wire as small as he's using anyways. Now I'm gonna have to give this a go again. Thanx.
One day I will know enough about electronics, but not any time soon.
Old 09-02-2003, 09:42 AM
ph2t's Avatar
I believe micro_amps uses what is known as "wire wrap" wire. I know it sounds funny but it goes back to a style of prototyping circuits where all the components were not soldered but had there connectors "wired" together to make a connection.
I know this sounds confusing but I know the shop where he got it from (a popular aussie electronics store, jaycar) and I believe that's what this store's cataloge said.
ph2t.
Old 09-02-2003, 10:24 AM
boho's Avatar
Camera springs
Cool, I wish I could find that stuff here.
Old 09-02-2003, 11:38 AM
MS_Modifier's Avatar
MS_Modifier MS_Modifier is offline
i have a 4.2 do you??
Send a message via AIM to MS_Modifier
for the fet mod i just sued a peace of cat 5 about 10 MM long and bant it right and cut all the plactic off with my exacto and for the short "wire" the gap was smallenuff that i just used soder (see pic)
its a jeep thing and you won’t under stand
with a 4.2 motor and mosfet
next mods will inculde fiber op lights!!
Old 09-02-2003, 12:34 PM
Matic Matic is offline
I also have trouble finding those thin wires ,but I found a perfect solution. Buy an ordinary Ultra-ATA 100 computer cable. It is cheap, wires are very thin and "SINGLE" - almost the same as Micro-amps uses....just the color is grey.....
boho's Avatar
Camera springs
Thanx. That's a good pic.
Silver magnet wire for a motor Horshu XMODS Parts and Hop-Ups 1 02-25-2005 11:44 PM
Honda Civic Antena Wire Problem!!! Xmodracer1 XMODS Parts and Hop-Ups 23 05-29-2004 05:01 PM
Antenna wire fix Gaian XMODS 1 01-05-2004 07:24 PM
XH XMOD Wire Upgrade Kit NOW TAKING ORDERS XAnubis XMODS Parts and Hop-Ups 8 12-12-2003 03:09 AM
A stupid question: Switched Reverse mod wire colors = ? frizzen Bit Char-G Mods and Projects 0 01-12-2003 10:37 PM
