Old 08-30-2003, 11:44 PM
thelaz71 thelaz71 is offline
mosfet mod
Hey I want to do the mosfet mod.I know its already on here 10 times but I couldn't find it. What will I need and any diagrams will help as well. Its on a zip and graphs for zips would be great for this mod. Also its on a gen 1 pcb board with a 2f2f purple engine do I need a new battery or anything? let me know all you can I have not done a mod since the "no reverse mod"
Old 08-31-2003, 01:02 AM
also I just soldered through a few steering wires so if anybody has had to fix that before let me know. I think I got the routing figured out I just need to solder them back on in the right order.
Old 09-03-2003, 11:25 PM
I Shall Return!
help is on the way
alrite hey im glad 2 help... first off look at this tread http://tinyrc.com/forums/showthread....ghlight=mosfet it'll answer most of ur questions... basicly u glob on sodder over 2 resistors and it gives ur motor more current so u gain acceleration but maintain a normal top speed... i for 1 am glad i did it... its a great power booster. the only downside is that u loose runtime by about 50% im not sure if you can run multiple batts wit dis mod so i posted my own tread... ne way about oyur steering wire ur not alone, i think i snaped every1 1 of mine but i got a easi fix
1- get some sodder on a soddering iron
2- get sodder on 1 end of snapped wire
3- place other wire in the sodder and its fixed
i hope this helped.. if u got ne more questions ur wanna kno more about mosfet ill b happy 2 help just email me at xxspeednplayaxx@hotmail.com ttyl
~M1K3
Old 09-04-2003, 10:29 AM
Labmonkey's Avatar
Labmonkey Labmonkey is offline
Tortured Primate
hey speed? that is not a mosfet mod. totally different mod you just linked to. also this mod worked for a few people on some of the earlier generation zips, but a lot of people noticed no difference or loss in power. unless you are confident in your soldering abilities, i would advise against trying this one...because more than likely you will need to go back to the original parts. if you are good with soldering surface mount parts, then give it a shot.
anyway, the original point was this was not the mosfet mod....i don't know if there is a complete record of how to do this mod...i don't have time to search it out at the moment, but feel free to search it yourself... i bet a majority of what you find is ads for microamps..lol
labmonkey
Imagination is more important than knowledge...
Albert Einstein
Old 09-04-2003, 02:31 PM
I Shall Return!
thnx
ok thnx lab... im sry im pretty much a nub i havent even played with my ZZs yet i wus to busy wit skoo and suma but now im goin all out... i have a newer ZZ cuz i killed my old 1 so do u think dis resistor bypass is good?? ur would u disagree against doin it??
Mosfet Mod jittery and jerky, help? jdog29 ZipZaps SE 3 06-03-2004 04:12 PM
Mosfet mod for Precious clones? FilipinoFreak Bit Char-G Mods and Projects 0 04-23-2004 02:20 AM
Se Mosfet Mod Available Stateside! cyborgzero ZipZaps SE 4 12-18-2003 01:45 PM
MOSFET mod for BCGs micro_Amps Bit Char-G Parts and Hop-Ups 90 11-11-2003 04:03 PM
mosfet mod!!!!! micromatch Bit Char-G / MicroSizers 3 08-20-2003 01:52 AM
