Old 08-30-2003, 01:52 PM
Yugo DSC Maxxer's Avatar
Yugo DSC Maxxer Yugo DSC Maxxer is offline
Zip Zap SE Basher
Send a message via AIM to Yugo DSC Maxxer
Looking to do an Controller Anenna Mod...With a switch.
Ok...I have a really, really small switch. (3 prongs, can fit inside a bit front tyre) So, can I make it so that I can switch from stock antenna and extended antenna? I want to do that so I can let my freinds drive without letting it get lost. Or if I am in a tight area.
PS: I'm using an antenna off of a Kyosho KT-2 Perfex antenna.
PPS: What type of wire should I use?
This'll be my first soldering job, even though I've practiced.
Thanks for the help everybody.
My Bit Char-G (Currently dead): and a Perfection 4.2....There really needs to be an icon for the 4.2's.
I got a Zip Zaps SE!!!
Yay!
The DIP Switch Mod ph2t Bit Science 8 08-19-2003 09:05 PM
controller mod natedogg4674 ZipZaps 2 01-10-2003 12:27 PM
controller mod & solution for poor range natedogg4674 ZipZaps 4 10-13-2002 09:40 PM
cheap zz controller joystick mod lnx_author ZipZaps 12 10-13-2002 12:21 PM
