Old 08-26-2003, 12:41 AM
Micro_R/C_Nut Micro_R/C_Nut is offline
My car wont turn right--Help
Hi guys i'm new to the forum. I just received my first bit char-g and i tried to take out the cripple capicitor on the pcb board and now my car wont steer right... i'm such a idiot...i literally got it for 1 hr and its already busted...
I heated the solder with a "fat" soldering gun (not the best tool but it did the job) and yanked out that lil sucker. But then after trying it worked but no right turns.
here's a pic of my pcb board if it helps at all.
plz if you have any suggestions feel free to help me out.
THx
Old 08-26-2003, 07:41 AM
DarkTari's Avatar
DarkTari DarkTari is offline
BitPimp Enforcer
First off Nut, you should've cut the crip/crap out. Never use the wrong tool as you said you did. That fat tip emmits a lot of undirected heat. I can't say for sure but either you broke the right steering wire somewhere or damaged that part of the board. I can't see if you've cross soldered anything cause you pic is fuzzy. See if you can get a clearer pic of both sides and repost.
DarkTari
If It Don't Fly....."MODIFY"!
Old 08-26-2003, 06:20 PM
viperkilla's Avatar
Acura RSX
man that sucks that you only had it for 1 hour....u should contact hobbico and see if they can send you a replacement chasis as long as you're under warranty...thats what happened to me (except i didnt brake my chasis)...i told them that my car wont move...then they sent me a new chasis within 4 days....they are very helpful....espcially "Mary Ann"
Old 08-26-2003, 06:29 PM
eman1 eman1 is offline
custom title
Send a message via AIM to eman1
I think mary ann is the only one there. Seems strange but true. I emailed them twice, both times it was mary ann.
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
Plantraco desktop rover for sale
email me at eman54@optonline.net if you want it
Old 08-26-2003, 07:04 PM
Tari,
Well there is nothing to cut on the car's pcb board u have to desolder and using tweezers remove the cripple capacitor. Usually in the controller there is a cripple capacitor that needs to be cut but thats easy plus mine doesn't have that in its controller. Yes i know i used the wrong tool but its not as fat as i explained it but its not that fine of a soldering iron either. The amount of heat that it generated was not enough to damage the car but i guess that could be a possibility. I think you are right in saying that some of the solder could have spilled onto another part therefore inhibiting it to go. I'll try removing some with a desoldering braid. I'll try to post a better pic.
killa, i think i will talk to ann and see if i get a new chassis but i don't think so, if u remove parts of the car u void the warranty but i'll try if i'm not successful in repairing it myself.
Thx guys i'll keep everyone posted
Old 08-26-2003, 07:31 PM
Lord_Nick_D's Avatar
Lord_Nick_D Lord_Nick_D is offline
I cant stop modding
your not soposed to tell them you modified it in any way
and this only works for microsizers I dont think they do it for bits
Old 08-26-2003, 10:33 PM
I fixed it. It had nothing to do with my soldering job. In my haste I took out the pcb board to fast and the right turn wire that connects to the board came out. So i just soldered it back on. Works beautifully.
Thanks for the help anyway guys!
ABC CRP problem: Turn left when accelerate ikinari ABC DTM Electronics 25 05-10-2004 03:04 AM
car wont turn please help Caseman XMODS 12 12-01-2003 09:22 AM
Tuning Basics sperry XMODS Parts and Hop-Ups 12 11-19-2003 01:56 AM
Car wont go backwards... Drag00n Bit Char-G / MicroSizers 3 11-15-2003 12:56 AM
Cat5 vs Cat5E for car antenna material mechanist ZipZaps 6 10-13-2002 01:59 AM
