Old 08-24-2003, 09:39 PM
Zephyranthes's Avatar
Blitzer Sonic
How do you fix this?
Broken car antenna.
Old 08-28-2003, 07:50 PM
Sky Sky is offline
I bought a new one. They are pretty cheap, But you could also Get some Music wire, and make custom ones.
Xmod Customizer
Old 09-01-2003, 11:02 AM
tinyrc's Avatar
tinyrc tinyrc is offline
http://mini-zracer.com/shop/productr...eyword=antenna
Old 11-09-2003, 06:00 PM
kevinsupra90's Avatar
kevinsupra90 kevinsupra90 is offline
Brownie Cheesecake
I just had some extra wire laying around and used it. It was rubber insulated, so it won't get fryed in the batteries. I just bent the end into an "O," connected it and coiled it up inside the body. The cool thing is, I've never had to use entry tags, since I put it in.
My 2 Mini-Zs are like cake, mmm...cake. My 3 Zips are like gerbils, small, quiet and cuddly.
Old 11-09-2003, 09:40 PM
viperkilla's Avatar
Acura RSX
I've heard that some people made their own antenneas with some wire.
Old 12-06-2003, 03:07 AM
379 379 is offline
when the antenna on my ol broke i coiled up around 2ft of fence wire inside the body and left just enuff to make it look real with the no taller than the roof sticking out and nearly 2ft coiled up inside it i gained some rang from it and never broke it again drilled a hole just under the right front pilllarand threaded an ince thru and secured it from the inside with duct tape tried elec tape and nearly fried the fet switched to duct tape and held much better and looked more scale
In my garage, X-mods and Mini-Z are not competitors. Both get stuck just as easy, pull the same amount of weight and are equal on fuel. Why be picky?!
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 02:32 AM
how can you fix scratch windows census007 XMODS Mods and Projects 3 01-26-2004 02:09 PM
How do I Fix This? ugh Bit Char-G / MicroSizers 7 03-05-2003 09:55 PM
How Do I Fix This? ugh Bit Char-G / MicroSizers 4 02-17-2003 08:03 PM
