08-22-2003, 05:51 PM
SHYMERLOO!!!!
i have a huge dual cell problem.
ok i did the dual cell and the mod to charge multi cell cars from www.questformadness.com. but after i charge the car it doesnt run. when i try to run the car while its charging it works. i used 2 stock microsizer batteries. can someone help me to get it to work?
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
08-22-2003, 07:51 PM
i suggest makin a seperate stand alone charger...try makin one. charge it with that. its worth a try...sounds like its runnin off the huge amps the charger puts out...battery only puts out so many. its worth a shot at least.
-stealthboy
Blue Black Pearl RSX XMOD.
SB motor
6 Cell Mod
NO LONGER DEAD!!! WOO HOO!
08-22-2003, 08:34 PM
bitPimp
Your problem is most likely not with the charger, but with your wiring in the car. I had this happen to me with one of my dual cells, and I'm trying to remember where the problem was. I think that depending on what style of dual cell you made, the charging pads may still be in circuit with the PCB and motor, but the batteries are not. Double check all your wiring, and also make sure you didn't toast a battery if you soldered wires to the ends.
