Old 08-20-2003, 03:37 PM
dmoh7 dmoh7 is offline
Unhappy MY CAR WON RUN PLZ HELPe\
Well i just performed a lowering mod on my car yesterday... i cut off the tab then lowered it and crazy glued it on.... after that it ran for a bit then stopped.... so i take off the cover and the car ran fine for a bit then stopped.... now after a full charge it wont even move, with a body on it or without.... and i just replaced the batteries 3 days ago!
Old 08-20-2003, 03:45 PM
denden's Avatar
denden denden is offline
Mini Rc Enthusiast
Try taking the battery out of the chassis . Put your car
on the charger and run it . If it runs , your
wire connections should be ok , I would then focus
on the battery or the tabs that hold the battery .
If your car doesn't run , check your wires . or simply
replace the batteries again . New doesn't always
equal good .
Hope this helps .
Old 08-20-2003, 05:56 PM
crazydave's Avatar
Garage Rocker
That's good advice from denden.
If you have a volt meter around you could use that to check your battery.
Rally car gallery crazydave Bit Char-G Gallery 34 06-07-2003 09:58 PM
2 Many Problems Plz Plz Help!!! Calsonic_racer Bit Char-G / MicroSizers 4 04-25-2003 10:43 AM
In Car Crip Cap Questions poopeebum Bit Char-G / MicroSizers 0 11-18-2002 11:21 PM
NEWSWEEK's mini car shootout-guess who won?? ICH_BIN_GUT! ZipZaps 6 11-08-2002 09:10 AM
HELP! Car Stutters, etc. DrakZ1 Bit Char-G / MicroSizers 4 09-13-2002 05:25 PM
