Old 08-15-2003, 07:26 PM
Got 4.2 King? I do : )
king 4.2 woot
i got my 4.2 and my 4.2 pro today and these motors scream.
i've only used them both in a single cell car and havent found which is faster yet. i've used stock and speed gears and the acceleration is like a turbo 4 banger, this turbo is putting out like 25 lbs of boost though, its slow off the start but it just cruises across the floor once it gets to top speed, my mom just washed the kitchen floor which is linoleum and i had this thing do about 3 barrel roles on a turn with stock tires
if you want it for a tourque moster not the right motor if you want crazy top speed this is the fastest motor i've seen
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 08-16-2003, 02:31 AM
as i've been driving it a while the motor seems to get more acceleration
also i found that my shen goes alot faster off the line than my ms is this normal? i tried the king and that king pro and what ever motor was in the shen was faster than my ms
i'm begining to think that the ms/bits arnt all their cracked up to be
the only thing their good for is their turning and axles the motors have no tourque they have terrible range they go slower with the same motor, oh but they have nice bodys
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 08-16-2003, 08:20 AM
MicroSpeed's Avatar
I've had the same results with my 4.2 combo, exept I run it without the body (lighter) and without front wheels (doesnt flip over, less rolling resistance) and it also flys. I like the normal 4.2 king better than the pro, even tho I have a pro, because it seems to go faster and my perfection 3.5 motors endcap is exactly the same color (blue). Another thing I like about it is while using stock tires (all 4) and a 200mAH battery, when the battery started running down the wheels had enough dust on them and the motors was going only slightly slower it would do 3-4" drifts
overall it is great and anyone who doesn't have one has got to get one!!! I mean, a little over $4 for 2 motors +S&H you cant get a 2.2 for that!
ZZSE + Perfection King 4.2 == WTF? ax0n ZipZaps SE 4 11-13-2003 01:03 PM
4.2 king motor schmock Bit Char-G Mods and Projects 2 10-03-2003 08:07 AM
can a zzSE run a perfection king 4.2? NOS man ZipZaps SE 4 09-18-2003 07:44 PM
motors: KING 4.2 MOTOR vs. KING 4.2 PRO MOTOR fusionlude Bit Char-G / MicroSizers 2 07-25-2003 05:16 PM
Review: perfection 4.2 Pro vs 4.2 king and 200mah batts eman1 Bit Char-G / MicroSizers 10 07-24-2003 04:41 PM
