08-09-2003, 08:43 AM
Trouble with new Lxx type R
Hey all, I know there are some really smart people on here, not to mention a lot that have had experience with trial and error, so i figured it'd be worth a shot to ask a question here. i recently purchased an Lxx Type R 35 mhz Zent Supra set from toyeast... it worked great up until...well...it stopped working. Anyways, my problem is is its range suddenly shot down out of nowhere from 10 feet to about six inches. I don't know if there is a crip cap anywhere on these pcbs or the controllers, and i even replaced the stock car antenna with a new solid copper one, and still i got nothing. I've checked for the most obvious mistakes, and I haven't messed with the board other than desoldering/soldering in the new antenna. has anybody else had a problem like that from they're Lxx Type Rs? Or perhaps somebody might know some things off the top of their head that could be the problem. The other two Lxx's <both type Rs> i purchased from them work fine. Could i possibly have recieved a defective one? If you guys think so, i'm pretty sure i can still return it...i've only had it for two days. Anyways, any help anyone could give would be greatly appreciated. Thx, you guys rock.
-Stealthboy
Blue Black Pearl RSX XMOD.
SB motor
6 Cell Mod
NO LONGER DEAD!!! WOO HOO!
08-09-2003, 09:35 AM
I should be getting mine in a few days (maybe today, it's the Denso Supra) and I'll post whether I have problems, but it sounds like yours is defective. Email toyeast (they make the LXX's)
and see what they'll do about it. For future reference see my thread LXX Type-R.
-David
08-09-2003, 12:24 PM
Monoaural.
my zz just did the same thing  the antenna fell off and i soldered back on, worked for a charge or two, then range dropped so much that the remotes antenna has to be right next to the car  any ideas?
J-On
08-09-2003, 11:04 PM
Camera springs
You might want to open the transmitter and check to make sure the antenna is still connected properly. There was a problem with one of mine once. It was because the connection from the circuit board to the antenna had come loose.
Check to make sure the antenna on the car isn't touching other metal parts, like the heat sink.
Other than that, I would say that if it worked once, then it should work again, unless you fried it somehow.
Hey vtheo, is there an online site that I can find the motorworks cars and stuff?
08-10-2003, 12:33 AM
Thanks guys, I'll open up my transmitter tonight to double check. I made sure nothing was touching the antenna, no go. I have hope though, as my old microsizer skyline did somethin like this a while back. stopped working, i got mad at it and cut off the top...then my little brother touched it and it worked again...so is the story of how my drop top skyline came to be. But thanks again, i'll be emailing toyeast to see if we can send it back and see about a replacement. Microspeed keep me posted on your denso supra. I hope i just got a bad one for everyone else's sake. O and check out my posts in micro's Lxx type-r thread to hear about my mad range boost! Anything that simple is worth a shot!
-Stealthboy
SB motor
6 Cell Mod
08-10-2003, 06:31 PM
Monoaural.
uhh, not that i know of, i have only seen them at walmart, if your walmart doesnt have them maybe they could order them for you, htey arent on the site either. btw i am using the tall tires from my motorworks on my zz, awesome ground clearance.
J-On
08-10-2003, 06:50 PM
hey stealthboy, my LXX is comin' tomorrow, And I will post a review of it, and I'm also getting more stuff from toyeast in the same box, which I will reveiw also. Heres my 'bought' list:
-Denso Supra-comes with perfection heatsink and perfection 3.5 motor
-Perfection 4.2 & 4.2 PRO
-Perfection Headlight kit
-2 200mAH batterys for dual cell'
-Perfection Decal set (Honda, Nissan, Mitsubuishi, Shell, Nismo, etc.
-David
08-10-2003, 07:29 PM
Monoaural.
well i have a few 49mhz remotes, all have the same prob with the car, i redid my solder job and add some more, a little to much now, i have a solder bridge between the resitor right next to the antenna spot, i think that was my prob to begin with, know just to figure out a way to remove that solder...
J-On
