Old 08-06-2003, 05:49 AM
hazzamaya
cutting own treads
i wos just wondering if you could cut your own treads in stock tires instead of payin £$£$£$£$£ for new treaded tires.
Old 08-06-2003, 09:55 AM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
You could.
The best way to make them grippier though would be to take a dremel (rotory tool) with a sanding drum attachment and touch the tires a lil bit. This should ruff up the tires a bit and soften them up making them grip better.
____________________
Meh.
Old 08-06-2003, 12:43 PM
charliebrown's Avatar
Yeah, but also take a little electrical tape, wrap the sticky side around, and run it like that, then take the tape off.....very grippy tires, OR you could just cut LOTS of slits in the tires. That works, too...Or just drench the tires in water and dry them, they are dry and brand new again.
add cells without cutting wires! theMonster XMODS 2 11-20-2003 01:16 PM
radio cutting out v0lc0m85 XMODS 12 11-04-2003 03:02 PM
Loose Treads? Strider Combat Digi Q 2 04-14-2003 05:49 PM
does antbody answer treads anymore??????????? zombiebaby Bit Char-G / MicroSizers 5 12-28-2002 06:05 PM
