Old 08-04-2003, 10:42 AM
Got 4.2 King? I do : )
fullsize wheel mod
whats the advantage to doing the fullsize wheel mod? do the bigger wheels get better handling?
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 08-04-2003, 11:00 AM
I have a beach ball...
You will get a slight handling increase, but your turning radius will increase greatly. So far the best wheel mod I've done is pullback rims.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 08-04-2003, 04:11 PM
MATRIX
ive done 1 wheel mod to my MS sport, using DUB City wheels.
Old 08-04-2003, 07:33 PM
i'm thinking about doing a wheel mod but does the front end look funny with the bigger wheels since its higher off the ground
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 08-04-2003, 09:24 PM
zztop zztop is offline
TinyRC addict
lower it
micro s2000,
lower the front..depending on the body you use, yu should have plenty of room up under there to accomdate the bigger rim and tire...i like lowering the front using a hard finger nail file...and filing the top of the existing tab hole....carefull to keep the cut clean..then use a "shim" of your preference ( i used a steel wire, it looks like an intercooler tube), to fill in the unused space on the now enlarged tab hole
i love clones
Old 08-04-2003, 09:50 PM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
actually doing the full-size wheel mod makings turning radius smaller because the tire snaggs on the body which causes one wheel not to move as freely while the other can causing sharper turns. Outta all of my bits my favorite is my skyline with zipzap rims and tires because it handles alot better.
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
3.8 motor (well, it doesnt want to run now)
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
Old 08-05-2003, 04:45 AM
boho's Avatar
boho boho is offline
Camera springs
They just came out with some new kit racers here in Japan. They are called bit racers here though. They have some different rims that I think look pretty darn good. I just put a pair on the lambo super (red one).
Also, I've been looking for a good, cheap toy car like hot wheels or something that I could cut off some rims and throw them on bits. Any body done that?
Old 08-05-2003, 07:25 PM
TinyRC addict
my two cents worth..well 3 cent including postage
when i did the full size mod to my bit..it rubbed the body a lil wheni cornered..so i found out exactly where it was rubbing and used a blade to "shave" away a little bit of the body....now it corners like a gokart....try sand paper if ya dont have a steady hand..its a little more leaniant toward mistakes....good luck
i love clones
Fullsize wheel mod and bodies... Vyrus Bit Char-G / MicroSizers 4 08-18-2003 09:29 AM
Small size wheel mod? tobenjunk Bit Char-G / MicroSizers 9 08-13-2003 01:03 PM
Wheel Mod Help ugh Bit Char-G / MicroSizers 8 07-18-2003 12:20 AM
Wheel mod on stock rear end slotsurfer Auldey (All) 2 01-12-2003 11:45 PM
