Old 08-03-2003, 11:49 PM
charliebrown's Avatar
A possible idler gear from the source of the Layman's cells...
Umm....could this be a possible idler gear???
http://www.allelectronics.com/cgi-bi...-83&type=store
And while we're at it, somebody once mentioned that a REGULAR dual cell will outrun a Layman's dual/tri cell because of the higher current and more torque. Is this true? If it is, then watch out ActofGod, because people may be reverting back to the old method!!! -jk
Old 08-04-2003, 04:05 PM
civic freak's Avatar
civic freak civic freak is offline
Tiny RC Guru
im not sure but i think it has to many teeth on tha outside and on tha inside, but to make sure youll have to talk to Ahh5hit, Tiny or Numanu
Old 08-04-2003, 08:25 PM
micro_Amps's Avatar
micro_Amps micro_Amps is offline
A fet modded single cell will out run them both, especially up hills.
Massive torque increase and speed too.
Check out the site in my sig line.
uA
Old 08-04-2003, 09:48 PM
MicroAmps.............
ENOUGH WITH THE MOSFETS!!!!
"the need for speed: a fast MT gearbox" chilli_mp138 ZipZaps Monster Truck 1 12-20-2005 06:58 PM
The maximum gear ratio..... charliebrown ZipZaps 9 01-13-2004 04:55 PM
Got to thinking... source of cheap 3.7v Li-Ion Cells... ax0n Bit Char-G Parts and Hop-Ups 3 09-19-2003 10:46 PM
button cells for layman's mod TypeZer0 Bit Char-G / MicroSizers 3 06-18-2003 10:18 PM
HELP Brand New Bit Char-G 1.0 Very Slow & Axle, Idler Gear Loose Sid Bit Char-G / MicroSizers 3 02-14-2003 11:37 AM
