Old 07-22-2003, 12:23 PM
Lestertech's Avatar
Lestertech Lestertech is offline
Drag racer
I am going to make a super fast drag racer but I was going to put a tri cell and a wheely bar to start with if any body has any ideas it would be great if you told me.
You know ya ar a red nek if ya porch colapses and kills mor than 4 dawgs.
Old 07-22-2003, 12:52 PM
BabyKiller's Avatar
... cut the tri cell do a quad cell
+ (4.8v)
Old 07-22-2003, 01:47 PM
Labmonkey's Avatar
Labmonkey Labmonkey is offline
Tortured Primate
ahh5hit's wheelie bar is the coolest.
great pics and instructions here.
http://tinyrc.com/forums/showthread....threadid=12318
Imagination is more important than knowledge...
Albert Einstein
Old 07-22-2003, 02:13 PM
BabyKiller's Avatar
get some wide rims and tires for the back get teal ms gears and get aholde of a 7t pinion to increase speed pick up some 4.2's underglow 200mah cells
heres what i run my zz with
fornt back with 7t pinion i still havnt gotten my 4.2's >
+ (4.8v)
Old 07-22-2003, 02:57 PM
Bad Company's Avatar
Thanks labmonkey! Also, you can get your wheels from this car...
Old 07-22-2003, 03:00 PM
They have the perfect tires for the front. You may want to add the spring suspension too to soften the landing to prevent the front wheels from being damaged because they are pretty skinny. Note: the turning is horrible with these front wheels, but if you are gonna use it for drag, then you will be ok. Here is my drag car with the wheelie bar labmonkey mentioned and the same wheels.
Old 07-22-2003, 04:46 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
how well does these hotwheel tires grip? r they even rubber?
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 07-22-2003, 05:02 PM
Yes, they are real rubber. The front tires are basically a oring wrapped around the rim. The steering is bad since there is no surface area for the tires to grip. Other than that, the rear tires do grip, but not as good as regular Zip tires.
Old 07-22-2003, 08:08 PM
ridealot100
Question
how do you install them and do you have to drill at all and how much do they cost
Old 07-23-2003, 08:52 PM
That Hot Wheels diecast was $7.99 at Target. You basically install them as you would any other wheel mod. Just perform a search. You do have to drill thru the front wheels. You have to be extremely carefull as they are very thin.
Old 07-25-2003, 08:21 PM
ripper7777777 ripper7777777 is offline
I used muscle machine tires, the grip is good on carpet, now I just need 30' of carpet...hehe
Old 07-26-2003, 02:19 AM
Char-g Ace's Avatar
Char-g Ace Char-g Ace is offline
I need to change my Title
r...rr....rr...r thoose zip zaaps(said stuttering)???
4 Bit Char-g Failiers
1 Microsizer
3.8 motor
Duel Cell sucess
Celica body
Old 07-30-2003, 02:23 PM
BrokenMonkey's Avatar
BrokenMonkey BrokenMonkey is offline
Send a message via AIM to BrokenMonkey Send a message via Yahoo to BrokenMonkey
woah. those r AWESOME!! did you make those or what? r u selling any? those r COOL
Can't think of a signature now
Old 07-31-2003, 12:18 PM
Lestertech's Avatar
where did you get those sweet bodies
how did you fit a zz chasis in there
Old 07-31-2003, 02:11 PM
vtheo's Avatar
vtheo vtheo is offline
Monoaural.
Send a message via AIM to vtheo Send a message via Yahoo to vtheo
look up streched chassises, and ripper7777777, every time i see those my mouth goes
J-On
Drag racer,...or ricer? crazydave ZipZaps 13 05-11-2003 09:55 AM
modified a body to fit Speed Racer Spec 1!! nojodash Epoch RC1/43 0 01-18-2003 09:16 AM
Tuning Ur Drag Racer bitpro Bit Char-G / MicroSizers 1 01-01-2003 10:07 PM
Dynamite Rocket Racer or Mini-Z?? tiny_dealy Other Tiny RCs 5 08-09-2002 11:34 AM
