Old 09-23-2002, 05:33 AM
retroicon retroicon is offline
Cripple Cap On Car Board... new evidence...
Hello all,
I've seen a few posts about the cripple cap on the board of the actual car and after examining my celica with HORRIBLE range I noticed the new little brick.... notice the solder around it looks horrible... as though it were added after the fact...
I did remove it and got about 2 inches extra range.... so I'm not sure if it actually does anything.. but the solder DOES make it look like it was added after the fact for sure.
Icon
Old 09-23-2002, 08:19 PM
datamonster datamonster is offline
I'm with stupid^
Send a message via AIM to datamonster
yep, i took that sucker out a few days ago. I didnt see any significant change in range. Maybe a couple of inches that i didnt notice.
Old 09-23-2002, 09:04 PM
lilaznboi
How do u take it out?
Old 09-24-2002, 12:48 AM
I'm with stupid^
you take it out with a soldering iron and some solder wick. just heat up the solder around the crippler and wick it up with the soldering wick. then you'll have to cut it off with an exacto knife. it takes a while to do it though. Only try this if you have experience with soldering on small things.
Cripple Cap. soggyrice.mMmMm Bit Char-G / MicroSizers 0 03-15-2003 09:47 PM
u have a 27mhz skyline(white) cant find cripple cap pakiplaya Bit Char-G Mods and Projects 1 12-16-2002 03:18 AM
Where is the cripple capacitator on the circuit board? Ghost of Akina Bit Char-G / MicroSizers 1 09-11-2002 10:45 PM
