Old 07-19-2003, 09:39 AM
RobotGT's Avatar
RobotGT RobotGT is offline
SUPREME RULER
Possible quad cell laymens mod!
I came up with an idea for a quad cell laymens mod. i didnt figure out if it would fry the pcb, or even fit, but here it is!
full size zz wheels
Old 07-19-2003, 02:47 PM
cyberkidd007
It would prob. fit in ZZ but you would have to flip PCB and then some lowered bodys wouldnt fit nice idea though
Old 07-19-2003, 08:15 PM
Jtskty Jtskty is offline
Master Debater
Send a message via AIM to Jtskty
And it wouldn't be a laymans mod anymore.
Old 07-19-2003, 10:30 PM
RobotGT's Avatar
SUPREME RULER
thats true, it would be the umm robotgt mod then!
full size zz wheels
Old 07-19-2003, 10:34 PM
SkyLiNEz 4-eva!
what voltage would you have for each battery? i think it'd be pretty freakin awesome, but it would make your car a helluva lot heavier. and you would have slow race times but long life.
Old 07-19-2003, 10:55 PM
boho's Avatar
boho boho is offline
Camera springs
First, for a bit, switch the positive and negative. They are on the wrong sides, unless that's a bottom view.
Each battery puts out 1.2 volts. So a quad cell would put out 4.8 volts.
It could fit in a bit, but you would have to cut/dremel a little room out (probably).
Unfortunately, a dual cell nicad would still be faster because it puts out more current (ma). I messed around with these batteries. For a dual cell (laymens) those little batts are a little faster then a stock and don't give it as much weight as a regular dual cell. Great for control variations. But adding any more then 2 doesn't really increase the speed all that much because you are adding weight, without adding enough current to compensate for the weight.
Yes increasing the voltage will increase the speed, but if you have too low current then you wont have enough torque to reach that top speed.
ALTHOUGH, it might be awsome in a mosfet modified car,because that lowers the resistance, witch will increase the overall usable current (torque). Somebody should try that.
Old 07-20-2003, 05:24 PM
RobotGT's Avatar
SUPREME RULER
Red face ME WANT COOKIE!!
Well, how hard is a MOFSET (SP) cuz if it isnt that hard ill do it. So if i did that how many normal cells would it equal?
It'll be called the "Rob's tribute to laymens mod!" heh, i think that s the worst name for a mod except "penut butter rocking chair omlette mod"
full size zz wheels
Old 07-21-2003, 01:52 PM
dr1zz's Avatar
dr1zz dr1zz is offline
phear meh..............
mosfet power is mostly torque.........although a dual cell will win at a drag race, the mosfet would win the track races
weight is a big key, as with mosfets, their is hardly any change in the weight of the car
i would compare it with a internal dual cell :
mosfet>dual @ acceleration
dual>mosfet @ top speed
i have a fet'd internal dual cell car that is purely wicked. i have to keep repairing this monster due to the stunt driver in meh
i personally dont like the laymans mod, cuz the runtimes are extemely short, but i guess it would be great for drag races
Old 07-21-2003, 06:02 PM
Ovgron's Avatar
Ovgron Ovgron is offline
I own you
you could just run a dual series dual paralell. kinda heavy, but still, 2.4 volts and double run time.
1/8 X-Terminator
1/8 Thunder Quake
1/10 Nitro Blizzard
1/10 E.Stampece
1/10 E-maxx
1/10 Evader BX
1/12 Nitro Legends
1/12 Digger 2
Old 07-21-2003, 09:17 PM
Master Debater
I was gonna post that but didn't know how to say it.
Old 07-22-2003, 10:12 AM
RobotGT's Avatar
SUPREME RULER
So you mean just do an external duel cell, cuz ive done 2 of them and i wanted to try sumthin new. iid prolly be better off jus duel celllin it.invisible, Oooo
full size zz wheels
