Old 07-17-2003, 09:09 AM
proboarder_33 proboarder_33 is offline
Stering Problem
My Bit char-g will only steer right and not left
Old 07-17-2003, 09:21 AM
boho's Avatar
boho boho is offline
Camera springs
Open the steering column. Check magnet and wires. If the magnets not centered, then center it and glue it into place. Make sure there's no glue on the outside of the magnet. Also, while you have it open put a small dab of superglue on the tip of the steering spring where it makes an "O". This will help keep it on better and help control a little.
If a wire is broke then get ready to do a pain in the butt soldering job.
Old 07-17-2003, 09:54 AM
thnx for the advice my magnet had stuff all over it like metal chips and stuff but now i cant get it back 2 gether prperly help??????
Old 07-17-2003, 11:49 AM
SkyLiNEz 4-eva!
take the chassis and put the 2 very short bottom prongs in the holes. then put on the piece with the magnet on the top rear shorter than the tall prongs. holt the magnet piece upright and then put on the clip and screw it back in place.
Old 07-17-2003, 07:51 PM
I go it goin the left wire was off so i saudered then when closing it i pulled the right wire off so i had 2 sauder it on
Old 07-17-2003, 11:59 PM
SkyLiNEz 4-eva!
good call...that's what you should do!!! you get a gold star! LOL!
Serious Problem... Pocket_Rocket XMODS Parts and Hop-Ups 10 11-08-2003 04:02 PM
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
Dogbones popping out? No problem. bluemax_1 Mini-X 3 04-01-2003 10:39 PM
Transmitter problem (picture included) ryanhook Bit Char-G / MicroSizers 11 12-26-2002 08:29 PM
AH-HA!!! Solved uneven steering problem! mechanist ZipZaps 8 10-17-2002 09:24 PM
