Old 07-13-2003, 02:25 AM
boho's Avatar
boho boho is offline
Camera springs
super bit charge mosfets
I've got a super bit/porsche. It seems to have an extreme amount of torque. Can somebody check the mosfets and see if they are putting out less ohms. I put a 3.8 in it and it still has tons more torque then the old stocks. In fact any motor I put in seems to achieve it's top speed very rapidly in the new bits.
Also has anybody experienced any glitches yet? mine sometimes continues to go forward or back after I let off the gas. I wasn't pushing anything else either.
Old 07-13-2003, 08:08 AM
PseduoRooter's Avatar
PseduoRooter PseduoRooter is offline
I hate suits!
Yup mine does the very same thing. And the tires spin quite a lot on take off. Even with the stock 1.6. I put a KIT 2.6 in my LP500 till I get something better. Man does it ever spin now!
Old 07-13-2003, 09:06 AM
jono123
ME 3
im having the same thing as u guy with my lambo includin the stiking motion. is any of ur ranges realyy rubbish aswell say about 5 to 6 feet?
i cant find a crip cap either?????????????
i think the body of the lambo is beute though
Old 07-13-2003, 01:46 PM
I hate suits!
My range seems to be slightly better than average for an unmodded bit. I definately get more than 5 or 6 feet though.
Old 07-13-2003, 07:55 PM
boho's Avatar
Camera springs
My range is pretty darn good. It sounds like tomy forgot to use quality control on these cars.
Also, my prsche's chassis has a very low ground clearing. It kept catching on little pieces of crud on the ground, or it would catch easily on carpet. I wipped out my dremmel and went to town. Made the ground clearence higher. It doesn't get caught on crap now.
Old 07-14-2003, 01:41 PM
jono123
how much range du u lot get?and any suggestions why u r getting so much range and im not?mine is a 27mhz A
Old 07-14-2003, 02:06 PM
hue35's Avatar
hue35 hue35 is offline
I don't own one of these cars yet, but I'd bet the smaller rear wheel diameter has a lot to do with the increase in torque.
hue35
Old 07-14-2003, 04:08 PM
I hate suits!
The tires on the new ones are the exact same size a pullback wheel. Not as wide mind youn but same height.
Old 07-14-2003, 05:30 PM
hue35's Avatar
Right... and, that smaller diameter is what delivers the extra torque.
Old 07-14-2003, 08:03 PM
I hate suits!
Makes sense.
Old 07-15-2003, 12:08 AM
nghts's Avatar
nghts nghts is offline
Send a message via Yahoo to nghts
if ur getting sliding wheels it might be that one of the wheels is loose on the axle, happened to me once
AMC Represent
Old 07-15-2003, 06:13 PM
I hate suits!
Not sliding wheels, just lots of wheelspin on takeoff. Seems to be due to the slightly smaller rear tires
Old 07-15-2003, 06:39 PM
DarkTari's Avatar
DarkTari DarkTari is offline
BitPimp Enforcer
They all have about 0.1 ground clearance (none) but a set of 9.5mm alloy's will take care of that!
DarkTari
If It Don't Fly....."MODIFY"!
Old 07-17-2003, 07:41 AM
boho's Avatar
Camera springs
Jono, sorry I never got back with you. Mine is 27mhzB. As far as why some get good range and some don't, well that's a bit of a mystery, to me at least. I've tried all the range modifications, but some just won't get much better. It's a fact we have to live with. Until I became a communications electronics guru, then I just wont understand it fully.
I do know that most bit/micro cars don't have enough power going to their antenna though. They have weak signals because of weak design.
Take r/c planes for example. They use controllers that put bit controllers to shame and they average about 200~800ft range.
Oh, and Tari, those rims are money. That's my next project.
Old 07-17-2003, 09:12 AM
boho's Avatar
Camera springs
Hey, anybody check those mosfets yet? I have a cheap multimeter, but I'm not sure exactly how to test it. Also, it's cheap. It might not be able to test it.
I just ordered a bunch of batteries. As soon as they get here I'll dual cell the super bit. I'll let you guys know how it comes out and compares to the old ones. Right now the stock super does seem to have alot on my old stocks, if I could just fix that friggin sticking problem!
super bit char-g? big-key Bit Char-G / MicroSizers 7 08-09-2003 11:26 PM
Super Bit Char-g Questions Tam Bit Char-G / MicroSizers 10 07-26-2003 01:38 PM
Speed racer mod bit charge Crystal Method Bit Char-G / MicroSizers 5 11-24-2002 10:55 AM
