Old 09-22-2002, 01:01 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
ZipZaps: Antenna Mod pics available in Gallery
HERE
One of the easier mods I've done. The LAME ZZ antenna HAD TO GO!
What you need:
- Pencil tip soldering iron (I used a 30watt)
- 24gauge, or thinner, solid core wire (that's my preference anyway, 24gauge is a bit heavy so you might want to go thinner)
- Some solder, of course
Procedure:
Note: Refer to the pictures in the Gallery if any of my descriptions seem a bit vague.
Preparation:
1. Cut the new antenna to length. (Actually cut a little more than you need, it's easier to cut any extra off, than it is to redo!)
2. Strip about 1/8" from the tip of the new antenna, then coat it with a little solder, this is going to be the part that gets soldered to the PCB.
Remove the old:
1. Press the tip of the soldering pencil to the solder point of the old antenna. Once the solder liquifies, you should be able to pull the wire right out.
Install the new:
Note: The solder joint for the Antenna on the PCB is actually a hole through the PCB itself. This actually makes life much easier!
1. While pressing the new antenna tip against the 'hole', appply the soldering pencil on the opposite side to liquify the solder
2. Once the solder liquifies, the antenna tips should slide right through the hole
3. Let the tip go through just enough to have it poke through the top just a little.
That's it, you're done and now have a new Antenna on your ZipZap!
Old 09-25-2002, 11:07 AM
tinyrc's Avatar
tinyrc tinyrc is offline
Namuna, looks great - what kind of range did you get before and after this mod?
Old 09-25-2002, 11:13 AM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
I just did the mod last night, and it extended the range only 2'-3' at most. But hey it looks better . I'm using a 27mhz freq. what freq. are you using Namuna?
Alberta modders dabigpig Bit Char-G / MicroSizers 2317 12-07-2006 10:02 PM
Track and Antenna Mod pics Robotguy ZipZaps SE 2 04-12-2005 01:01 PM
ZipZaps Ultimate Fan Contest at Zipzaps.com cj1267 ZipZaps 4 07-09-2003 11:37 PM
help :( antenna mod :( crip. cap. soggyrice.mMmMm Bit Char-G / MicroSizers 3 03-17-2003 07:04 PM
ZipZaps wheels on a Bit: Pics now available in Gallery Namuna Bit Char-G Mods and Projects 6 09-26-2002 10:37 PM
