Old 06-26-2003, 10:50 PM
faulkbeets's Avatar
faulkbeets faulkbeets is offline
not so bright
Send a message via AIM to faulkbeets
zz cars into boats...
I was down at a creek behind my house and i had an idea of a zip car conversion into a boat...but the thing is there are many ways to do this and i want your opinions and ideas. My idea was get a styrofoam box that could hold the car (palm size), then get some thin wires bend it over the back of the half box holding the zip with a propelor on one end of the wire. The thing is i havent put too much time into this so i wouldnt really know how to put the gears a spinnin. Remove back wheel and make a custom one for this job...thanks
deace out
Old 06-26-2003, 10:57 PM
charliebrown's Avatar
It won't work. The water will get into the mechanics and mess it up. Other people have had this idea and failed at it. Sorry, but it is a hard thing to master.
Old 06-26-2003, 11:00 PM
faulkbeets's Avatar
not so bright
maybe u get wrong idea the thing is fully *well not fully* protected the only thing exposed is the top of the car and the propelor would be totally in water so it wouldnt splash up
deace out
Old 06-26-2003, 11:07 PM
My bad....But I would like to see the steering.....that would be tight!!!
Old 06-26-2003, 11:09 PM
faulkbeets's Avatar
not so bright
i guess that could be done with some kinda connection to a fin behind the motor causing it to turn
deace out
Old 06-27-2003, 01:23 AM
crweedon crweedon is offline
i think that making kinda of like a hovercraft but without the hover, cause that would require alot more power and toque, but like have a propeller and the eletromagnets turn a little rudder to direct the air, or if you really have you heart set on a boat, you could do anyhting like wire in extra motor or two or just use the existing electromagnets to drive a fin on the underside of the boat through a shaft or something.
Old 06-27-2003, 01:31 AM
Cool Dad's Avatar
Cool Dad Cool Dad is offline
Drive It Like Ya Stole It
Check these out...
http://harcohobbies.com/mini-rc-boats.aspx http://www.nkok.com/productdetl.asp?...&catscale=1:64
These look pretty cool. Anybody here ever seen one in action? Based on what I've seen the average price is around 15 to 20 bucks. If I had my pick I'd get the red one.
Old 06-27-2003, 12:10 PM
faulkbeets's Avatar
not so bright
thanks cool dad
deace out
Old 12-22-2003, 01:26 PM
nitrousmaniac nitrousmaniac is offline
D1 Grand Prix
just get a boat from like hot wheels or somthing, get two spare motors and solder wires to and from the battery and the engines. get some electrical tape to protect the motors from the water and heat up a nail and melt a clean hole (if the boat is plastic). Peace
Old 12-22-2003, 11:55 PM
Rotary Freak's Avatar
Rotary Freak Rotary Freak is offline
Send a message via AIM to Rotary Freak
Weird, I was thinking of this earlier tonight. Welp, I know a BIT Racer can live through water. Tested it tonight..wouldn't have a control method..but it'd go.
I wish my Land Rover was a rotary
Old 12-25-2003, 12:24 PM
D1 Grand Prix
maybe som how set up a second motor to turn a steering thing? like the things that sail boats use to steer. i have a fake clone "stunt vehicle" and it comes with two motors to work with so if u hook up the second motor to be a steering mechanism or somthing...
R u calling me a welp??? im only trying to help buddy.
Old 12-26-2003, 11:43 PM
viperdout's Avatar
It's Really Fast!
You're looking at this thing like you're Rube Golberg (did I spell that right?). What you need is another gear riding on the axle gear, then runs it up or down to a prop w/ a propeller. This would allow for "driving" straight into water. Then a rudder could be hooked up to the steering. It would work well with a ZZ SE. You run a second servo in parallel, then hook it up in the back on a rudder with a hinge. there ya go! Make a hull, waterproof electronics (shrink wrap), and you're set. The only problem is charging. For that, you'd have to make a wire that would "plug" into the controller. Another one of my rants, but I think that sums it up. Also, it would go into water like this car...
http://www.watercar.com/video.html
Project Bad Brushless:
Just say no to giant sigs.
Old 12-27-2003, 01:21 PM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
Originally posted by Cool Dad
Check these out...
ya...they have those at the walmart here in my town....i am going to get one...(once i get rechargable bats and level 2 motors for my xmod...).....
-Andres
Old 02-26-2004, 07:48 PM
TWilsonTX TWilsonTX is offline
Send a message via AIM to TWilsonTX
walmart, micro boats 14.99, 50 ft range, mde by the people who make monster trucks, use zz motors and standard bats, two motors, one stops or reverses to trun it.
I feel The Need, the need for speed! -Top Gun
Old 02-26-2004, 08:04 PM
viperdout's Avatar
It's Really Fast!
Yeah, but I like the challenge of making my own boat.
Cars transmitter rody ZipZaps 1 04-08-2007 08:49 PM
Great..more micro cars to collect (Speedez) Rotary Freak Miscellaneous Discussion 6 02-15-2004 08:17 PM
After market bodies Roadrunner Bit Char-G / MicroSizers 58 01-17-2003 12:53 AM
