06-26-2003, 10:48 PM
Wowzers...
Problem With Steering Wire
Oh man, this one's got me stumped. Okay, my friend asked me to fix his MS Pro because it wasn't steering "right". So, I looked in and saw a copper wire (steering wire) ripped. Assuming it was taken from the PCB, I got my soldering iron ready and opened it up. To my surprise, both copper wires were intact. I searched the chassis and found that the wire had gotten separated in the middle. Does anyone have a clue how to fix this problem?
Nothing here...
06-26-2003, 11:15 PM
I have a beach ball...
Just splice the two ends together.
06-26-2003, 11:40 PM
Wowzers...
How can I splice them together? (not said sarcastically)
Nothing here...
06-26-2003, 11:55 PM
ok take both wires and remove some of the coating (lighter, sandpaper, soldering iron all work) then twist the two ends together and now heat up the wire connection you just made and feed it some solder..... tada it should work now.
***  AMC Veteran  ***
-- ^-_-^
06-26-2003, 11:59 PM
Once you do that, I'd start looking for how it happened in the first place.
06-28-2003, 01:34 AM
I need to change my Title
i screwed up and the r steering wire came unsoldered. it is bad timing because i have this "mini" convention on tuesday. My soldering gun is messed up, but i need to solder to fix it. any tips?
4 Bit Char-g Failiers
1 Microsizer
3.8 motor
Duel Cell sucess
Celica body
06-28-2003, 01:59 AM
TINY RC RULEZ!
mix some iron filings with araldite then you have a no heat solder
07-04-2003, 02:20 AM
Camera springs
Soldering paste makes the solder stick to where you are soldering.
