Old 06-25-2003, 08:13 AM
Weapon-NZ Weapon-NZ is offline
to any1 that has done the ultimate light mod or is good in electronic
ok this is for anyone that has done the ultimate light mod found on this page http://www.age.jp/~ex2/bit/01_custom_e.html or is good at electronic
anyways im planning to go buy some leds and do this mod, but one thing im trying to change is using an external battery source rather that used in the car, reason being i want my car's run time to be long, besides i plan to use hi intensity leds which the battery already found in the car wont power.
Im pretty new to electronics, infact i only started learning it at school this year, but im already pretty good with the soldering iron and positive that im capable of soldering the small bits found in the diagram, anyways does anyone know how to add a bigger battery into the diagram? im planning to use one of those button cells or maybe to so that it can power my led?
I was thinking of maybe adding the battery before the "vcc" OR disconnecting the wire leading from the vcc and conecting it to the grnd and in between that add my external battery. Would this idea work or would it give that power to the whole power circuit rather than just the "leds" part?
Old 06-26-2003, 12:41 AM
anyone?
Old 06-26-2003, 02:04 AM
frizzen frizzen is offline
Tool User
It looks like you've got to tap the board no matter what (to get the signal)
The only way to make this so it won't hurt speed or duration much is to keep it from sucking the power down. And that's to use Transistors or FETs. You'll have to modify the circuit and probably the car's pcb cover, but it should be able to work.
Maybe try surface mount stuff instead of the normal size, easy to use ones.
I understand what they're doing, except for one thing. Where do you install the 200uf cap??
Old 06-26-2003, 02:53 AM
i actually want to use an external battery instead than that of the one in the car already due to the fact that i want to use hi intensity LEDs which are rated at like 3 or 4 volts. Maybe i can put it before the vcc and use a diode or something? im not really sure though since im new to electronics
Old 06-26-2003, 10:54 AM
teamoutburst's Avatar
teamoutburst teamoutburst is offline
TINY RC RULEZ!
I'm making my own 'ultimate light mod' with a seperate board and a small picmicro chip on, this board is already made, i just have to assemble it to night and then program the PIC.
My Car:
Old 06-26-2003, 10:56 AM
TINY RC RULEZ!
For those high intensity thingies use a boost convertor, if you look in bit science there are a few topics one of which is named ''New Dual Cell''
My Car:
Old 06-27-2003, 12:12 AM
lol no one seems to understand what im trying to say, maybe im typing it wrong? lol anyways i'll try to explain it again..
Is there any way to do the ultimate light mod but use an external power source?
Old 06-27-2003, 01:42 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
yeh, grab some small transistors, hook up the emitters and collectors in a loop wiht one of the led and the battery. run a wire from teh base (middle pin) to wherever on the pcb like F if ur doing it for the headlights. do the same for each set of lights and run the battery in parallel with all the loops so u only have one power source. i'll make a diagram when i get time, probalby after work tonite
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 06-28-2003, 02:32 AM
thanks alot dude, much appreciated
Old 06-28-2003, 12:00 PM
TypeZer0's Avatar
0reZepyT
ok, this circuit should work. jus figure out wut value resistor u need to limit the current to the LED. if this is wrong or wutever, plz correct it
File Type: jpg ultimate light mod with external power supply.jpg (10.3 KB, 88 views)
Old 06-28-2003, 05:36 PM
thanks alot dude
also with the extra battery and the layour, would the extra voltage fry the pcb board?
Old 06-28-2003, 08:04 PM
TypeZer0's Avatar
0reZepyT
if ur referring to my drawing, no, the only connection to the bit's chassis woudl be the base connector on those transistors. other than that, it's a self contained circuit. u could even stick a switch right before or after the battery to disable it
Old 06-28-2003, 09:02 PM
hehe thanx alot dude, time to go the the electronic store
oh does it matter if the transistors are PNP or NPN?
Old 06-28-2003, 09:31 PM
TypeZer0's Avatar
0reZepyT
actually, i'm not sure wut's the diff, gotta look it up, but i bought this for a diff project that i never bothered to do and i tink these are fine
Old 07-02-2003, 06:07 PM
ph2t's Avatar
ph2t ph2t is offline
Chief Propeller Head
use NPN
What is good to use for the controler mod? ssghchd ZipZaps 1 12-21-2002 08:25 PM
Whats a good (and easy) first mod Colt45101st Bit Char-G / MicroSizers 7 11-25-2002 01:59 PM
does any1 no a good website for micro sizer accesories douglas123 Bit Char-G / MicroSizers 5 10-09-2002 01:52 AM
a good drag mod i figured blacksabbath070 Bit Char-G Mods and Projects 3 09-08-2002 04:43 PM
