Old 06-24-2003, 10:01 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
Dream Car
my dream car would be a :
blue s2k
suspension springs
Li-Poly
Phast motor
Lowered
Pullback wheels
perfectioon heatsink
double steering springs
what would ur dream car be?
Old 06-24-2003, 10:08 PM
Aquarius's Avatar
Aquarius Aquarius is offline
MS Pro Know It All
Orange Murcie
Suspension Springs
Phast Motor
MS Pro PCB
Perfection Heatsink
Mosfet Mod
Dual Cell
Old 06-25-2003, 12:53 AM
isk8blind's Avatar
isk8element too.
lamborgini diablo(silver w/ lighter silver flames)
5 speed
proportional sreering & throttle
mosfet mod
4 200mah batt's
lowered
dual phast motor
kit racer gears
spinner rims(keep spinnin when yah stop)
soft tires
super soft springs
solid coper wire antenna 20g
full size wheels
thats allllllllllllllll folks. pretty sweet huh?
2 BCG nissan fairladyz
2 MS sport honda s2000
1 LXX auto modellista booster
2 ZZ yellow &black honda civic
and 3 clones & a pcb.
Old 06-25-2003, 02:04 AM
Aquarius's Avatar
MS Pro Know It All
I wouldn't mind having one of those either. lol
Old 06-25-2003, 02:59 AM
Smurf Smurf is offline
Lube Master
Send a message via AIM to Smurf
Bb open deck
tricell laymans
mosfets
4.2pro (it is faster then a phast motor i have both a phast and 4.2pro the 4.2 is ALOT faster)
Under car lights
Full size wheels
Pimp uv color changing paint job
cant think of anything else
also phast motors really dont have enough torque to start if you have another motor on top im guessing. they really have no low rpm torque.
http://www.halffull.net/phast.jpg
Phear my phast motor icon!
Old 06-25-2003, 05:36 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
-Skyline R34
-Fully propo throttle
-Fully propo steering
-Front suspension that mimics real car's suspension better
-Easily interchangeable spring suspension with diff stiffness
-Headlights that go on when in forward
-Brake lights that stay dim when cruising, full brightness when no throttle for 2 seconds or when in reverse
-Turn signals when you turn
-Motor connected to at least a 2 speed tranny, ball diff, and a couple of CV joints for actual rear independent suspension
-Redesigned chassis and pcb with re-positioned components so that it sits lower and gets closer to a 50/50 weight distribution
-A "turbo" function that engages a dc-dc converter to double the voltage to the motor....kinda like nitrous oxide cuz if u do it too much/too long it will destroy something
-Pneumatic tires
-A digital color vid cam that's very very tiny with 525 lines of vertical resolution and transmits at 30 fps to a receiver to get full motion full color hi-res driver's view
-A cell battery the same size and weight as the one used in Layman's Dual Cell Mod that provides 3.6 volts and has a capacity of 2000mAh and will take a very fast charge wihtout destroying itself
....gotta go, may update later with more wishes for the perfect dream bit.....yeh i know what i wish for is not possible or very expensive to implement but hey, who cars, its my DREAM car right? hehe, i like everyone's dream car idea here tho but i like mine better
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 06-25-2003, 06:37 PM
AUDI-TT's Avatar
żżż Whats that ???
Old 06-25-2003, 06:44 PM
isk8blind's Avatar
isk8element too.
lamborgini diablo, thats a car
spinner rims, there special rims so when you stop they keep spinning
Old 06-25-2003, 07:09 PM
AUDI-TT's Avatar
thats cool, but what does it do? is it just to look cool??
Old 06-25-2003, 07:10 PM
nouseforname101
Originally posted by TypeZer0
-Skyline R34
-Headlights
-A cell battery that provides 3.6 volts and will take a very fast charge wihtout destroying itself
A few edits but thats pretty much an Epoch(Spec 1 or Spec 2 with a Spec 1 body) with a Lightkit from HLJ. If you want the working signals then get a DGmaster even though they arn't nearly as good as an Epoch. Spec 2s are also better than Spec 1
Old 06-25-2003, 09:39 PM
TypeZer0's Avatar
0reZepyT
true, but i'd like to have it bit or zip sized
Old 06-26-2003, 06:47 AM
JackD JackD is offline
ITCOB
Booster Chassis
dual cell
MOSFET MOD
4.2 Pro
with a '57 Chevy Body
Old 06-26-2003, 10:20 AM
MicroSpeed's Avatar
'03 Honda Civic Type R
4WD (driveshaft goes through motor and out both ends
Mini Z motor (mounted front to back)
4:1 gear ratio (for speed and keeping some torq)
Prop. Steering/throttle
Front-Rear independent suspension
ajustible wheelbase for use with matchbox cars, Johnny Lightning etc.
headlights-brakelights-turn signals
interchangeable CNC alloy rims
12+ different frequencys
20+ mph
Old 06-26-2003, 10:21 AM
MicroSpeed's Avatar
should only cost ~$500 US
Old 06-26-2003, 10:22 AM
MicroSpeed's Avatar
oh yeah and a ball differential
Dream Car Garage KingFuzz Miscellaneous Discussion 1 02-19-2006 09:02 AM
My Car doesn't work! Eyemfaster XMODS 2 03-02-2005 09:59 PM
What gears and motor should I use to get the most power out of my car with a trailer. AudiTF Bit Char-G / MicroSizers 6 11-14-2002 04:38 PM
Cat5 vs Cat5E for car antenna material mechanist ZipZaps 6 10-13-2002 12:59 AM
