Old 06-24-2003, 09:29 PM
SupraFreak00 SupraFreak00 is offline
Send a message via AIM to SupraFreak00 Send a message via Yahoo to SupraFreak00
Ahh5hit, Question.... again...
hey i saw how you but some rims from the Street Dubs. i went out otday to lok for parts and i ran across them,bought a set, and took it home to mod my cassis. i did the back axel, but for the front Axle what did you do to get them on there?!
Thanks a bunch.
Old 06-25-2003, 04:59 AM
Bad Company's Avatar
Remove the existing pin from a Zip Or Microsizer knuckle by pulling it straight out with pliers. You have to drill the new wheels out enough for the existing pin to go thru and still rotate. Then just insert the new wheels with the existing pin to the existing knuckle.
Old 06-25-2003, 09:08 AM
charliebrown's Avatar
Or you could just order a nice full size wheelset from RCmod.com
Old 06-25-2003, 03:16 PM
I think he was looking to install the DUB City wheels. The only wheel sets I saw on RCmod was the Hot Wheels and Microsizers wheels.
Old 06-25-2003, 04:24 PM
Ahh5hit,
Iwas just wondering... what did you do with the back axel..i twisted off the ZZ wheels and did a little shaving with a Xato knife and lt he threds in the axle keep it in place. as for the other side (the one with out the gears) i jammed it on there.. it seem to stay. it was alittle to loose so i made a fat roll of eletric tape around so it wouldn't silde. just for futher notice, what did you do?
Old 06-25-2003, 06:09 PM
Before attaching the non gear side, cut a piece of Q-tip tube and slide it over the axle between the wheel and the chassis so that the wheels sits identical to the gear side wheel.
Old 06-25-2003, 06:39 PM
Here is a pic for the above post...Yes, it is a pink Q-tip. That's what happens when you have a wife and two little girls.
Question for Ahh5hit, Payaso, anyone.....HELP ME!!!!!! ugh Bit Char-G / MicroSizers 11 07-28-2003 11:01 PM
Ahh5hit, answer this question for me. SupraFreak00 ZipZaps 5 06-22-2003 01:35 PM
Wheel axle question! MythosGR Bit Char-G / MicroSizers 1 01-26-2003 08:31 PM
Question, please awnser quickly. Supra-00 Bit Char-G / MicroSizers 17 10-25-2002 11:32 PM
Question about model putty... SPEED Bit Char-G Mods and Projects 1 09-28-2002 10:19 PM
