Go Back   TinyRC.com > 1/24 and Smaller > ABC DTM > ABC DTM X4
Old 09-19-2002, 07:12 AM
Ohm Ohm is offline
Question Gearing?
From what I've read the x4 gearing possibilities are:
pinion: 13 14 15
Spur: 29/16 30/16 31/16
Diff: ??? How many teeth are on the diff crown? Is it changeable?
And what's the outer diameter of the tires?
Thanks
Old 09-22-2002, 12:38 AM
gertman's Avatar
gertman gertman is offline
Sorry I never counted the number of teeth on the diff crown BUT they are they same front and rear.
As far as wheel diameter it changes pretty quick because they are foams.......and I don't have a new one to measure for you.
I do believe a 12 tooth pinion would fit on too.
-Engineering Manager
Gearing for mini-x bluemax_1 Mini-X 16 04-15-2003 07:59 PM
Gearing Info nrmcj Bit Char-G / MicroSizers 6 01-25-2003 12:35 PM
Shen gearing... shocon2k Bit Char-G / MicroSizers 3 12-31-2002 06:43 AM
Gearing Ratios? LCKKN]HT Bit Char-G / MicroSizers 2 11-16-2002 10:37 PM
Special editon gearing vrs normal gearing Smurf Bit Char-G Parts and Hop-Ups 2 10-09-2002 11:08 AM
