Old 06-07-2003, 09:00 PM
ph2t's Avatar
ph2t ph2t is offline
Chief Propeller Head
Working Indicator Lights!
Check dis......
For the full lowdown including circuit go HERE .
ph2t.
Old 06-07-2003, 09:06 PM
strider_mt2k
Woah! killer!
man, the breadboard looks like lumber at that scale, doesn't it?
Old 06-07-2003, 09:09 PM
ph2t's Avatar
lol! sure does strider. Check out some video of the lights in action.
On the test bench
Night Driving 1
Night Driving 2
All DivX format.
ph2t.
Old 06-07-2003, 09:46 PM
strider_mt2k
Absolutely way cool!
Very nice work man.
Old 06-07-2003, 09:53 PM
ph2t's Avatar
Thanks homie.
I'm now working on brake lights that are dim untill you stop when they then come on full brightness. Like a real car......
After that I'll get the front headlights going as well. They will be dim in reverse and stop mode. Then full brightness when going fwd...
ph2t.
Old 06-07-2003, 10:59 PM
midget_man1387's Avatar
midgetPimp
wow those lights are MINI! where'd you pick those up at? and also, how bright are they?
Old 06-13-2003, 04:41 AM
ph2t's Avatar
Midget, I got them from an aussie supplier. Just look online for SMD leds. That's Surface Mount LED's, much smaller than normal LED's. The yellow ones aren't that bright. I gotta up the voltage to about 5V so they shine a bit more. The DC-DC converter I'm using is one of the originals from a clone PCB, not very good. Driving 4 LEDS can suck a bit of current.......
Just wait till I finish the fully functional headlights and brake lights, now that's gonna look mad!
ph2t.
Old 06-13-2003, 01:16 PM
teamoutburst's Avatar
teamoutburst teamoutburst is offline
TINY RC RULEZ!
if possible could you post the schmatic
My Car:
Old 06-13-2003, 05:59 PM
ph2t's Avatar
Sure, here it is.
This doensn't include the 3V supply, you need to source that as well.
ph2t.
Old 06-13-2003, 06:55 PM
BabyKiller's Avatar
somwhere on the net a saw schmatics for recarable 5v lithium coin batteryies
+ (4.8v)
Old 06-13-2003, 06:56 PM
BabyKiller's Avatar
oh and how bright do these leds get with good volts i was sketchy on buying small ones like them
+ (4.8v)
Old 06-13-2003, 07:07 PM
ph2t's Avatar
These are rated at about 20-30 mcd which enough for this application. I'm experimenting with a 1.2V->5V dc-dc converter at the moment. The video shows the lights running on a 3V dc-dc converter...... These converters only work well for the LED circuit due to the current limitations.....
Old 06-17-2003, 09:37 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Brilliant stuff! I love it. BTW, where would such a circuit hook to a Zip? Great work.
Old 06-18-2003, 12:10 AM
ph2t's Avatar
I don't have a zipzap mate so I wouldn't know sorry. I got some old ZZ pcb's sessiz sent me, I'll have a look at them.
I've now got this running on a 5V source and the LED's are much brighter. Those DCDC converters are great!
Cheers,
ph2t.
Old 07-06-2003, 09:10 AM
t-squared's Avatar
t-squared t-squared is offline
Bit Obessed...
old post, but blah or well...
anyways, for your brake lights, won't it be easier to wire it up to the car's rechargeable batteries? Since when your car is going, its going to drain the battery, and therefore, your lights will be dimmer, then, when you coast, which is partically like braking, the LEDs would be their brightest, simulating the brake lights.......
but.......if you're not going 2x cells, you can ignore this post....
Not working kewlguy ZipZaps SE 10 12-23-2005 05:54 PM
No wonder my Layman's Tricell wasn't working! charliebrown ZipZaps 1 01-26-2004 05:17 PM
will trade for working 49mhz ZZ chassis rt450 For Sale/Trade 0 07-07-2003 02:01 AM
PCB Not working (Strange Dual battery symptoms) kenny_dilger Bit Char-G / MicroSizers 0 12-16-2002 11:59 PM
