Old 05-31-2003, 08:05 PM
micro kid's Avatar
micro kid micro kid is offline
Do you getto dremel?
Rear lowering.
how do I lower the rear of my bit? already lowered the front but it would be nice to have the back down too.
Old 06-02-2003, 06:15 PM
Lord_Nick_D's Avatar
Lord_Nick_D Lord_Nick_D is offline
I cant stop modding
file the back of the body slot upward
thats what I did on the front too
Old 06-02-2003, 08:13 PM
DriveWRX's Avatar
DriveWRX DriveWRX is offline
My How-to
I wrote a how-to with pics.
Check it out HERE.
Look for Lowering Mods parts 1-5 and Grill Work.
It specifically for the Skyline body. You'll need to adapt my techniques for different bodies.
Hope it helps!
MicroSizers Subaru Impreza WRX
Old 06-04-2003, 05:56 PM
Maxxcrazy Maxxcrazy is offline
skylinepimpinR34-Bit Pimp
Send a message via AIM to Maxxcrazy
Thanks for the tip, I think I'll use that. Could you lower it even more without having anything hit?
Skyline Microsizer
Thunder Charger Clone
Old 06-05-2003, 12:24 PM
midget_man1387's Avatar
midgetPimp
shens are ideal for lowering. they can be lowered without making the wheelweels appear different. All you have to do is shave the wheelwells on the interior to prevent rubbing they can get SUPER LOW!!!
Old 06-05-2003, 12:58 PM
DraGula's Avatar
DraGula DraGula is offline
TinyRC fool!
you could take front wheels from a different bit or buy some, and then put those on an axle equal to the size of a bit axle, and glue it on with a gear, and do the same with the other side, except using a spacer instead of a gear. You can also use custom wheels.
This is the lowering mod from QFM.
EDIT: if you do shave the inside of your body, you can take off the tabs and secure the body with putty to lower it to min. ground clearance. You may also want to use spring suspension.
I command you to: check out the site
Old 06-07-2003, 07:55 PM
I lowered my skyline. I didnt like how the fron was higher than the rear though. so I lowered the front by 2 tabs and the rear by 1 tab. I also put a body kit on the front and rear, so it sits 1mm off the ground
Skyline Microsizer
Rear suspension on a bit? chelboed Bit Char-G Mods and Projects 28 04-13-2003 09:51 AM
Solved KIT rear issue...... DarkTari Bit Char-G / MicroSizers 0 02-10-2003 10:48 AM
whoa, Taiyo rear is removable, meaning: CUSTOM T BAR REAR SUPSENSION MOD TIME!!! MTL Auldey (All) 6 12-30-2002 07:53 PM
Lowering Rear Suspension schoon Bit Char-G Mods and Projects 1 08-17-2002 02:49 AM
