Old 05-26-2003, 06:54 PM
Swavey's Avatar
Swavey Swavey is offline
Got Avatar?
Charging a Dual Cell
I have been thinking, would it be possible to have a dual cell spaced right and fit into the car exactly like the original battery, then add extra charge tabs and build a custom charger.....
Shouldnt you be able to charge both batteries individually that that way? Or am I just bein stupid.....
*** AmC Certified ***
Old 05-26-2003, 08:12 PM
BabyKiller's Avatar
all depends on how your wireing the charger
+ (4.8v)
Old 05-26-2003, 08:19 PM
Swavey's Avatar
Got Avatar?
This whole concept or idea, is a little hard to explain....
I have a diecast body that is exactly 3 inches, and for the wheel wels to fit perfectly the soace needed to extend it just happens to be the exact size of the space taken up by the battery in a bit (using a Shen clone) So I figured rather than hardwire a dual cell (will need one to power the diecast body) why not just cut out the entire battery holding soace from another shen and insert it into the project one.......
I hope this makes sence so far.
That way to can change batteries and such much easier in the long run. I just dont know the best way to wire it all up after i get it build, heh. Which ever way is best for Power i guess... Cause I want the diecast to fly like a mofo.....
Pics to come shortly of everything...........
Old 05-26-2003, 08:43 PM
BabyKiller's Avatar
well i would suggest a tri cell and max torque mod
+ (4.8v)
What??? Charging dual cell with original charger??? someguy Bit Char-G / MicroSizers 4 06-04-2003 07:08 PM
Layman dual cell charging Zephyranthes Bit Char-G / MicroSizers 3 02-18-2003 03:33 PM
Dual Cell Charging ugh Bit Char-G Mods and Projects 2 02-16-2003 01:04 PM
Charging for laymens dual cell. Zephyranthes Bit Char-G Mods and Projects 1 02-12-2003 10:02 AM
