09-16-2002, 02:41 AM
KIT wheels on Bit???
anyone know how i can use the gears on the KITs to my bit? How do i take the wheel apart? also, can i use the motors with the white pinion?
09-16-2002, 04:56 AM
i did the gear mod and i can tell you that the ratio isn't very good for bit char-g. the motors don't have enough torque. so the battery dies very fast. you're better off getting the gear set for bit char-g
09-16-2002, 07:51 AM
that sucks... ok.. thanks..... JENNIFER LOVE HEWITT COMING TO SEATTLE LATER THIS MORNING!
09-17-2002, 12:45 PM
Yeah, I tried both the red and green gear set from the KIT racers and they just plain blow...  Not to mention it really shorten the run time of the battery... With in no time it didnt have the juice to move itself....
Huh?
09-18-2002, 12:27 AM
Moderator - Modifier
Torque issue solution...
USe a 1.6 green dragon rotor. These are torquelicious. Should be enough to make use of the Bit axles. Or do a 2.4v mod. This will definitely give you startup power.
