Old 05-13-2003, 07:43 AM
Buzzbait's Avatar
Buzzbait Buzzbait is offline
Antenna Idea
I've read where people have made internal antennas that run inside the body of the car. Has anybody tried using an old steering coil from a dead bit, and using the coil as an internal antenna? It seems like a steering coil would make for one hella’ long antenna.
Old 05-13-2003, 10:39 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
never done that but you are probably correct.
Old 05-13-2003, 01:53 PM
BabyKiller's Avatar
what i do is wrap my antenna in tin foil and curl it up and place the body over it without the anteena sticking out and i get a extra 4 feet while its under the body
+ (4.8v)
Old 05-13-2003, 03:23 PM
hogjowlz's Avatar
i havnt ran my cars with antennas stickin out since right after i got my first or second car.
you get so much better performance.
Old 05-13-2003, 04:26 PM
Awaken's Avatar
Awaken Awaken is offline
Feh
Send a message via AIM to Awaken Send a message via Yahoo to Awaken
so is the wieght of wrapping foil around the antenna worth it?
Old 05-13-2003, 04:56 PM
hogjowlz's Avatar
a piece of foil aint that heavy
Old 05-13-2003, 05:55 PM
Awaken's Avatar
Feh
will it might be to a bit
Old 05-13-2003, 07:08 PM
metsrule119's Avatar
Actually, they suck^
dude even to a bit, foil weighs nothing. sounds like a good idea to me... im gonna try that
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Toy East Mini Cooper
1 Precious Clone
Old 05-13-2003, 07:12 PM
BabyKiller's Avatar
if it has any affect it would give it better traction and preformence
+ (4.8v)
Old 05-13-2003, 09:23 PM
Awaken's Avatar
Feh
ah ok heh i guess if your put alot it would be heavy...
Old 05-13-2003, 11:18 PM
Calsonic_racer Calsonic_racer is offline
MASTA POOOOOOOOOOOOOOTANG
how many times do you wrap it in alluminum foil?
MICROSIZER PRO: 2 SPEEDS, 1.3 NIMH, 49 MHZ, SKYLINE R34 GTR custom paint, pull back wheels, blue head lights
MICROSIZER SPORT: 1.3 nimh, rest is stock
panther= 2.4 nicd, rest is stock
MEGATOYS rc: rest is stock
bitchar-g: rest is stock
Old 05-13-2003, 11:29 PM
Awaken's Avatar
Feh
i guess once? and do you have to have the antenna wire touch the foil r just wrap it around it?
Old 05-14-2003, 06:15 AM
BabyKiller's Avatar
lol i do it like 5 time then grap each end and twist in opposite directtion to make in as thin as possible
+ (4.8v)
Old 05-14-2003, 12:56 PM
Awaken's Avatar
Feh
ah i see
Old 05-14-2003, 02:22 PM
hogjowlz's Avatar
good idear babykiller. cant believe i said that. heh
Best Antenna Idea For Reception mini rc man Bit Char-G Mods and Projects 2 01-24-2003 09:30 PM
Antenna idea M.O.B Bit Char-G Mods and Projects 2 01-09-2003 03:27 AM
beeper motor and antenna idea read ucntbta2.0 Bit Char-G / MicroSizers 1 11-24-2002 09:26 AM
antenna idea, bummer it doesn't work... john ZipZaps 5 11-07-2002 09:17 AM
