Old 05-09-2003, 08:30 PM
BitZipAddict BitZipAddict is offline
Suspension Springs problem
i installed the suspension springs on my bit. I cut the springs down (used the tomy springs from QFM). Now the steering isnt working like it used to. The wheels dont turn left and right when I hold it up, but i know the connections are fine becuase i can steer it while driving, but it doesnt go straight at all. Has anyone had this problem, or know how to fix it?
Old 05-10-2003, 05:36 PM
ph2t's Avatar
ph2t ph2t is offline
Chief Propeller Head
This usually happens when the springs are applying too much tension to the steering knuckle. This causes the knuckle to become very stiff when trying to turn and therefore killing the steering action.
Before mounting your steering assembly back in place make sure the springs are sitting like this.
Notice that the springs sit below the ends of the steering knuckles. This way when the assembly is put back together there is no excess tension on the knuckles.
These springs are custom made by myself and are available for sale in this thread HERE .
ph2t.
Old 05-12-2003, 05:21 PM
shanly
rare earth magnets help alot too,only 2 dollars at your local radio shack..
Old 05-12-2003, 05:28 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
those tomy springs are too stiff. there are other slot car springs that work much better. i got tyco roadhuggers. they cost about 75cents per car to do.
Old 05-12-2003, 06:28 PM
shanly
mine aint tomy springs,i bought a big accord modifyer and used those spring on the suspension..you might be able to make out the accord in the background in that pic i posted above...
better front suspension springs for SE? daver ZipZaps SE 1 01-22-2005 07:54 PM
Dual Rate Springs - Suspension Bad Company XMODS Mods and Projects 17 01-07-2004 10:22 AM
Suspension problem geofroley XMODS Parts and Hop-Ups 0 12-29-2003 08:43 PM
suspension springs are stupid Impreza WR reX Bit Char-G / MicroSizers 21 04-12-2003 08:30 AM
adding suspension springs...question MTL Bit Char-G / MicroSizers 32 10-22-2002 03:43 PM
