Old 04-28-2003, 03:29 AM
e_lm_70 e_lm_70 is offline
Tomica Limited : Problems !
Hi,
Is there any tricky for charge the car ?
When I plug my Tomica in controler gun, I can just see a 1milli-second flash on the red led ... no further sign of charging ... I tested the Vold in the two cell ... and it was below 2.2V ... ready for be charged !
Danke
e_lm_70
Old 04-30-2003, 07:11 AM
Captain Jeffo
The new Tomica Limited serie's hast to be charges as follows:
Turn off the Emitter and the car !!!!
Then you will see the red Led light up. As it seems the load function has a timer... load several times...for shure the first time...
and certain if you update your battery with a 200 mAh... one
Greetings,
See also www.MicroRace.be (mainly in Flemish for the moment)
but this car you can find under the UK flag.
More review in the comming hours
Tomica Limited 1/64 propo car mde Bit Char-G / MicroSizers 3 04-16-2004 07:48 PM
Tomica limited??? blind Bit Char-G / MicroSizers 3 06-11-2003 09:58 PM
New Bit Char-G! Canadian Bit Bit Char-G / MicroSizers 35 04-29-2003 01:38 AM
Problems with R-Specs... Vyrus bitchar-gmotors Customer Support 6 02-27-2003 02:02 PM
Steering problems Go0ty ZipZaps 1 10-08-2002 07:20 PM
