Old 04-11-2003, 11:34 AM
Spanky's Avatar
Spanky Spanky is offline
Mr. Goop
solar powerd bit racer
this guy gets props...
http://home.ust.hk/%7Ebcandyp/hof20.html
a solar powered bit racer... i wonder if you could convert that to a solar powered bit char-g... for non stop action outdoors!!!
Old 04-11-2003, 12:05 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
youd have to have this under high powered lamps in order to get enough juice to the motor. even then i doubt it would work as well as youd want.
Old 04-11-2003, 12:23 PM
Spanky's Avatar
Mr. Goop
outside. in natural sunlight is where you would get the most juice.. thats why i said use it outside.. preferably on a sunnyday..
i know it wouldnt be a pocket rocket, but it would be cool.. and whos to say you couldnt get a bigger solar cell or for that matter get 2 solar cells to put on the car...
even if it only went 1.0 speeds it would be cool...
Old 04-11-2003, 12:41 PM
Duratrax Duratrax is offline
Send a message via ICQ to Duratrax
Sounds cool but the solar bateri should be several times bigger then the little bit(i think) And this bateries are expencive
**** can happen
Old 04-11-2003, 12:45 PM
Spanky's Avatar
Mr. Goop
well if he could fit it in a kit racer im sure you could fit it in a bit char-g. yea its expensive but so is the li-poly.. if i had the moula i would give it a try...
Old 04-11-2003, 01:44 PM
Spanky's Avatar
Mr. Goop
i e-mailed the guy that made that car. I asked him how much juice that one solar panel generates, and here is what he said
"As far as I can remember, they put out around 3.5V for 24mm*33mm solar-panel. That is more than enough to chargemost of the caps, battery and run the motor for sure."
so if you are running outside on a sunny day you should be ok.. and it just might fly!!!
Old 04-11-2003, 02:40 PM
hogjowlz's Avatar
radioshack sells a solar kits.
here is their solar page
Old 04-11-2003, 03:09 PM
ib311's Avatar
ib311 ib311 is offline
Promoted to Pleb
nice find guys!
Old 04-11-2003, 04:25 PM
BillyP
I wouldn't want a solar powered bit, but if somebody built a solar powered charger, tha'd be great!
Old 04-11-2003, 04:31 PM
smokin'1320 smokin'1320 is offline
Send a message via AIM to smokin'1320
i once used a solar panal from a knex set on a tyco canned heat n addition 2 the aa batts it made it pretty fast when i ran it out side , but finding a panal that small might b hard.
carbon fiber, triple deck rear wing : $350.00
"Type R" sticker: $5.00
Stupidity: Priceless
shen qi wei NX
White Xmod supra 6cell Stage2Drift Light Kit awd
Old 04-11-2003, 04:44 PM
Lord_Nick_D's Avatar
Lord_Nick_D Lord_Nick_D is offline
I cant stop modding
in canadian radioshack they have these solar car kits and they use much larger motors so it must put out decent power also with solar energy it is stored so the power gets time to build up before you unleash it with 3V like that guy said
Old 04-11-2003, 11:04 PM
mc2wheels mc2wheels is offline
These guys are celling solar Atomic Z's
http://www.nmsea.org/Retail/solar_cars.htm
Old 04-11-2003, 11:14 PM
dabigpig's Avatar
dabigpig dabigpig is offline
talk about owning in an endurance race
*** AMC Veteran ***
-- ^-_-^
Old 04-11-2003, 11:41 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Sweet deal! I am gonna do this now! Screw my dual cell project, I have 4 solar panels
Old 05-28-2003, 05:59 PM
Rex's Avatar
Rex Rex is offline
Bob and Tom Fan
Send a message via Yahoo to Rex
Xatu, Did you ever get it to work?
When in Doubt... Improvise
Bit Racer gear mod 323iT Bit Char-G Mods and Projects 7 01-26-2003 09:12 PM
bit racer 2.6 vs. bit char-g 2.6...differences? spikeymike218 Bit Char-G Parts and Hop-Ups 2 12-20-2002 04:13 PM
Speed racer mod bit charge Crystal Method Bit Char-G / MicroSizers 5 11-24-2002 10:55 AM
Cheapest place to get Bit Racer tires? Ghost of Akina Bit Char-G Parts and Hop-Ups 7 11-11-2002 04:18 PM
Bit Char-G or Bit Racer tires? Bootylactin Bit Char-G / MicroSizers 4 08-24-2002 03:17 PM
