Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Digi Q
Old 04-10-2003, 02:43 PM
ViperKid's Avatar
ViperKid ViperKid is offline
Redneck Drifter
just got my Q and have a few questions
hello i just got my lancer and Digi Propo special and i have a few more questions...once you put the code in what do you do? also i pulled the trigger while the light was blinking will that hurt it? do you put the codes in after you charge? do you leave the car on when you change codes? thanks
Old 04-10-2003, 02:50 PM
ViperKid's Avatar
Redneck Drifter
when you are done driving should you leave it charged?
thanks again
Old 04-11-2003, 09:47 AM
ViperKid's Avatar
Redneck Drifter
hello?....Namuna?......anybody?
i know i sound like a newbie, but i spend alot of money on this little car and i don't want to screw it up
Old 04-11-2003, 03:37 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
- once you put the code in what do you do?
Start driving! With the code entered, you should immediately see the car behave in certain ways.
- also i pulled the trigger while the light was blinking will that hurt it?
No, it won't hurt it. As I understand it, that flashing light is while the car and transmitter 'sync up'...So if you start playing beforehand, the car might act unpredictably...But it doesn't hurt anything.
- do you put the codes in after you charge?
Put the codes in anytime you want. Before, during, after you charge...It doesn't matter
- do you leave the car on when you change codes?
Again, doesn't matter...Change it anytime
- when you are done driving should you leave it charged?
Depends. If you drive the car often, then it's okay to put it away drained...BUT, if the car is going to sit awhile without being used it should be put away with as full a charge as possible.
Old 04-11-2003, 05:19 PM
ViperKid's Avatar
Redneck Drifter
thanks a bunch...
your my hero
