04-10-2003, 10:56 AM
Dual Cell Pro
Heres a pic of my dual cell PRO that I stretched to the length of a ZZ.
04-10-2003, 10:57 AM
Heres a pic of the chassis
04-10-2003, 11:13 AM
Told ya.
Another excellent job ripper7x7.
____________________
Meh.
04-10-2003, 12:08 PM
State Property
thats awsome...your the KING of strechin..nice work..how long did that take?
04-10-2003, 01:20 PM
Re: Dual Cell Pro
Hey, i ve got smth to ask about all this mods.. If you connect the second batteri to increase the voltage dont tou just burn everything?
**** can happen
04-10-2003, 01:24 PM
Box Racer
nope! actually I believe the Tomy PCB can handle up to four batteries...I think that's the max. But anyway, no it can handle the voltage.
Underground Dweller: If I were you, I'd start running!
Buddy: If you were me, you'd be good lookin'.
--Quote from Six String Samurai
04-10-2003, 03:42 PM
Thanks everyone.
SlowbutCourious - It only took a couple of afternoons.
Duratrax - ShadowMage is right the pcb can handle up to 4 batts.
04-10-2003, 03:45 PM
theres no need for more than 2 batts unless you are trying to break a bit speed record.
04-10-2003, 05:50 PM
Zhuge Liang - My Idol
and yes the pcb can handle like 5 volts but the endbell can handle much less....
04-10-2003, 09:19 PM
Rice Me
 omg... ripper how you so good at this stuff?! damn, i wish i could do that...
sheit.. .sooo nice.... mad props man!
04-10-2003, 10:26 PM
State Property
what do u use to cut the chassis?
04-10-2003, 10:29 PM
I know how to do alot of that..but what i want to know, is what do you use to mold in between the chassis to hold the 2 peices together? Some kind of Putty i imagine, but what brand/type?
04-10-2003, 10:31 PM
props to you and all your streched cars
a prop
***  AMC Veteran  ***
-- ^-_-^
04-11-2003, 01:36 AM
Mr. Goop
i have heard of some clones coming with dual cells, and was wondering if the pcb's in those could handle more voltage or are they the same board.. im looking to do 6 cells. yea it sounds like a lot, but it is for my slot car motor mod. this motor needs a lot more than 2 cells. with 4 cells it is probably equal to a dual cell with a 2.2 motor. im setting this up to run on carpet.. as there is not enough traction on tile floor for this to get up to speed..
anyway any suggestions. how much voltage can a nachimichi racer take? anyone know?
04-11-2003, 10:17 AM
Spanky - I don't know, I built all my dual Cell Cars, I would imagine that the pcb's are basically the same.
dabigpig - Thanks for the prop.
CjsF150nNeon - I use lexan or polystyrene (which ever is laying around at the time) and super glue gel and then paint it with flat black, I only use putty on the bodies I stretch, no reason to add extra weight to the chassis
SlowbutCourious - I use a Dremel
