Old 04-08-2003, 11:35 PM
PTink's Avatar
PTink PTink is offline
i like pizza
Help with custom charger
This has probably been gone over many a time but i was just wondering if could get longer run times by charging my bit with the charging pad hooked up to a 9V batt. If i keep it on for a little at a time will it allow me to run for a long period of time?
i will only list the cars that i use once in a while...
ferrari 360 MiniZ; tons of new parts
Integra Type-R Epoch; Stock
Wild CharG; stock, the lifting one
White Skyline microsizer; only factory upgrades, for good handling
Old 04-10-2003, 10:17 AM
JC_focus_ZX3 JC_focus_ZX3 is offline
Send a message via AIM to JC_focus_ZX3
Considering the battery only holds 1.2 volts I think you would most likely damage your battery this way.
The best way to get longer run times is just charge it 2 or three times off the controller, or better yet get one of these:
http://tinyrc.com/shop/product.php?pid=438
If you really want some details on makeing a seperate charger that works and is safe, check Bit Science and Bit project forums.
Old 04-10-2003, 11:30 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
you can get a single battery holder from radioshack for a buck. you just gota wedge it in the controller battery circuit in series and use an insulator at the terminal. this charges a dual cell fine.
Old 04-10-2003, 01:25 PM
Newbster Newbster is offline
Send a message via AIM to Newbster
In order to charge the stock battery with the stock charger you have to charge it about 10 times for it to reach its full capacity. I got this from a reliable source on another forum and have done it myself and I got a 30+ minute running time (had to go to school so I couldnt test it further)
Im too lazy to make a signature.
car not running long, and some charger help.. tegboi Bit Char-G / MicroSizers 2 10-12-2008 10:09 PM
Custom Charger query ph2t Bit Char-G / MicroSizers 7 04-29-2003 06:48 PM
Custom Charger for dual cell RabieS ZipZaps 1 03-07-2003 06:09 PM
custom plug-in charger question blght Bit Char-G / MicroSizers 2 02-24-2003 11:09 PM
