Old 04-08-2003, 05:33 PM
smokin'1320 smokin'1320 is offline
Send a message via AIM to smokin'1320
no solder dual cell???
is it possible to do a dual cell w/o a soldering iron?
i killed one of my shens and im gonna harvest its battery4 the mod if it can b done
also link me to a tutorial if possible
carbon fiber, triple deck rear wing : $350.00
"Type R" sticker: $5.00
Stupidity: Priceless
shen qi wei NX
White Xmod supra 6cell Stage2Drift Light Kit awd
Old 04-08-2003, 05:35 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Yea, it can be done. Electrical tape all the wires.... But I'm not too sure about getting it on the PCB.
Old 04-08-2003, 05:55 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
what do you have against solder? im sure tape would work until you bumped it and something fell off and youd have to gut it and redo it every 10mins.
Old 04-08-2003, 06:01 PM
Heat's Avatar
Heat Heat is offline
Zhuge Liang - My Idol
i dont think he has one
Old 04-08-2003, 06:25 PM
PTink's Avatar
PTink PTink is offline
i like pizza
At first i had doubts about my soldering skills so i didint do it for a while, but then i did the cat5 mod and i feel great about it.
i will only list the cars that i use once in a while...
ferrari 360 MiniZ; tons of new parts
Integra Type-R Epoch; Stock
Wild CharG; stock, the lifting one
White Skyline microsizer; only factory upgrades, for good handling
Old 04-09-2003, 02:55 PM
SlowbutCourious's Avatar
State Property
..when i fianly got a dual cell 2 work 4 me i was usin tape until i got a solder iron... and u are better off usin a solder iron they do come undone ALOT if u use tape..its a pain...
Old 04-10-2003, 10:43 AM
hogjowlz's Avatar
you can get a 9$ iron that will work fine for these little parts. i did a pcb transfer the other night ago without even using fresh solder. i just used what was on the pcb already. the hardest part about soldering a dual cell is getting it to stick to the battery. sand the ends up before you apply the solder. search on google for a guide. im sure theres very detailed instructions.
Laymans dual cell vs. traditional dual cell Zephyranthes Bit Char-G Mods and Projects 6 02-18-2003 06:12 PM
and they said it couldn't be done! dual cell mod tory_103 Bit Char-G Mods and Projects 5 01-01-2003 07:03 PM
